01-16-2015, 20:18 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: remotely
Member: 2063388 Status: Offline Thanks Meter: 80 | att note4 n910a n915a efs wipe Dial *#9090# Press Menu Enter Q Press Menu and hit Back, After Enter Key 0000 Wait for couple of seconds... You will Prompt into MAIN MENU Select UE SETTINGS & INFO, SYSTEM, NV BACKUP TEST, EREASE ALL EFS1/2/3 and Select YES... Done EFS WIPE without ROOT..... i known about this for a wail but justmejose just relested it to the public so here you go guys and girls ! Last edited by blang; 01-16-2015 at 22:03. |
The Following 9 Users Say Thank You to flashing09 For This Useful Post: |
01-16-2015, 20:51 | #2 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
01-16-2015, 23:34 | #3 (permalink) |
Freak Poster Join Date: Jul 2011 Location: sweden
Member: 1609777 Status: Offline Thanks Meter: 55 | I TRY WITH N915F NOT HAPPEN ANYTHING Remained the same IMEI NOT WIPE. Thanks for the tip important. Any idea about how to wipe EFS FOR N915F . Was a try by all means unsuccessfully. |
01-17-2015, 00:41 | #4 (permalink) |
Member: 2063388 Status: Offline Thanks Meter: 80 | Up up down down left right left right a b a start select This wipes the efs for all phone every time it's the secret cheat code for samsung |
The Following User Says Thank You to flashing09 For This Useful Post: |
01-17-2015, 05:09 | #7 (permalink) |
Member: 2063388 Status: Offline Thanks Meter: 80 | I know . I mean any one that used the old unlock method for android via the service menu should have known about this . It's the simplest things we over look . Same with Open Sesame door It's been around since the htc mogul maybe even later and pepole still trying to figure out how to change the meid on htc's |
01-17-2015, 18:05 | #13 (permalink) |
Banned Join Date: Jun 2014
Member: 2206276 Status: Offline Thanks Meter: 46 | The exact way you wipe the efs on a n910f. They both have the exact same partitions. There is no need to use any service menu on tmobile or international versions. The bootloaders are not locked like on the at&t models. So you can obtain root and backup everything before you wipe efs. |
01-18-2015, 18:38 | #14 (permalink) | |
Banned Join Date: Jan 2015 Location: Inside Samsung Age: 39
Member: 2326685 Status: Offline Sonork: [email protected] Thanks Meter: 17 | Quote:
http://forum.gsmhosting.com/vbb/f684.../#post10757614 please stop acting like Samsung ***..... | |
01-18-2015, 22:17 | #15 (permalink) | |
