05-29-2013, 08:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: kocaeli Age: 46
Member: 58232 Status: Offline Thanks Meter: 91 | att s4 i337 repair solution 2 days i337 repair I'm working but not repair 2x pc format all driver again install 2-3 x stoc firmware odin flash not repair not repair imei 00/0 phone is dead hahahahah 1x phone 2 days finish solution found 1x phone 2 minute finish solution *#7284# not modem choice (not selection) pda choice (selection) *#9090# choice (selection) 4* restart root phone this file (only) [ROOT] Root Samsung Galaxy S4 with Motochopper - xda-developers z3x port choice not reed innfo vs vs direkt repair Now connect phone to UART cable (connect rj45 sam3300 cable) repair done Selected model: I337 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SGH-I337 Android version: 4.2.2 Product code: Not Active Phone version: I337UCUAMDB PDA version: I337UCUAMDB CSC version: I337ATTAMDB IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM3 OK Reading phone info... Model: SGH-I337 Country code: ATT Cal date: - Factory SW: I337UCUAMDB Unique number: C16B0CCA1073D10 Memory phone: - Bypass MSL... OK Repairing IMEI... OK Repair done Rebooting... OK Done with Samsung Tool v.14.5 |
The Following 2 Users Say Thank You to muzi_31 For This Useful Post: |
05-29-2013, 11:12 | #2 (permalink) |
Member: 58232 Status: Offline Thanks Meter: 91 | edit post not passible sory 1x edit z3x port choice not reed innfo vs vs direkt repair Now connect phone to UART cable (connect rj45 sam3300 cable) repair done 1. first normal usb connetck 2.second Now connect phone to UART cable msj see conneckt rj45 kable |
The Following User Says Thank You to muzi_31 For This Useful Post: |
07-01-2013, 20:54 | #3 (permalink) |
Member: 58232 Status: Offline Thanks Meter: 91 | total 7-8 phone repair same i337 phone repair after full signal and not call only emergency fix How to Enable T-Mobile HSPA+ AWS Bands on AT&T Galaxy S4 SGH-i337/SGH-i337M! | GalaxyS4Root.com |
01-27-2014, 06:37 | #4 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: [pujab haryana]
Member: 1481018 Status: Offline Sonork: 100.165460 Thanks Meter: 222 | Quote:
Yes this Ok WAy,,,,,,,,,, | |
