Old 09-24-2015, 16:52   #16 (permalink)
Member: 2346105
Sm-J110f Root File please help me????????????????
Old 09-26-2015, 09:50   #17 (permalink)
Member: 2335681
Sonork: 100.1668903
Thanks Meter: 21
z3x box card reder driver sand ok driver plase
Old 10-20-2015, 10:23   #18 (permalink)
Member: 1887022
Thanks Meter: 99
link not work ..........................
Old 10-27-2015, 20:08   #19 (permalink)
Member: 2468746
Thanks Meter: 19
Hi
I need driver for Z3X USB to Serial Converter for Windows 10 64-Bit. Please help
Hardware ID: USB\VID_0403&PID_0011&REV_0600
Thanks
Old 11-13-2015, 19:55   #20 (permalink)
Member: 2485774
pls pls help me
i have problem in z3x shell ( card not found ) .. i am using win 7 32 bit
thanks in advance
Old 12-29-2015, 15:54   #21 (permalink)
Ouzigzag's Avatar
Member: 1753151
Sonork: 100.1658597
Thanks Meter: 325
Originally Posted by blang View Post
Latest Z3X BOX ftdi driver ver.2.08.30
August 2013. All Windows x86 & x64
: Hotfile
*includes the following versions of the Windows operating system: Windows XP, Windows Server 2003, Windows Vista, Windows Server 2008, Windows 7, Windows Server 2008 R2 and Windows 8.
*Also, as Windows 8 RT is a closed system not allowing for 3rd party driver installation our Windows 8 driver will not support this variant of the OS.
Please Mr Blang provide the download link drivers for windows 10 64 bits
Old 05-02-2016, 11:17   #22 (permalink)
pitbulli's Avatar
Member: 1475192
Thanks Meter: 99
Originally Posted by kashif9 View Post
Hi
Thanks
report, driver for Z3X not working on Windows 10 64-Bit
Old 05-06-2016, 06:08   #23 (permalink)
Member: 99605
Thanks Meter: 57
I try instal z3x on 64 bit win 7 and win 10 and com port not working how instal z3x box on 64 bit system ?
Old 05-12-2016, 08:43   #24 (permalink)
Member: 10168
Thanks Meter: 136
Drivers trying to install and ending in a failure with a cryptic hash error message is because Windows 8/8.1 wants to use only signed drivers!
Here is how to enable non-signed box drivers (i.e. Z3X etc) install in Windows 8/8.1 64 bit
1. Windows Key + R
2. Enter “shutdown.exe /r /o /f /t 0″ – this tells the computer to restart and prompt how you want to start and Click the “OK”
3. The system will restart to a menu allowing you to change how it boots.
4. Select “Troubleshoot”
5. Select “Advanced options”
6. Select “Windows Startup Settings” – this will restart Windows and let us change the boot options and Click “Restart” button
7. System will restart to “Advanced Boot Options” screen
8. Select “Disable Driver Signature Enforcement” – this tells the computer to booth without forcing signed drivers.
9. Reboot the computer and install the device driver as normal (either using the installer if available or Device Manager)
Note: This needs to be done once again after the PC has been rebooted should another box need to added at a later date.
The Following User Says Thank You to jim.mahoney For This Useful Post:
Old 05-17-2016, 08:46   #25 (permalink)
Member: 99605
Thanks Meter: 57
On Win 10 this trick not working becouse driver not working when i directly show driver path z3x box become instaled but not work property. Z3X team please add good driver for win10 64 bit
Old 05-17-2016, 13:56   #26 (permalink)
Member: 10168
Thanks Meter: 136
I'm not sure Windows 10 can ever be used in the GSM world! Not for a few years!
If you let Windows upgrade then roll back to a working OS.
Old 06-04-2016, 10:29   #27 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,349
Yes I want too sighned win10 64bit drivers will be possible soon ??
All other box give sighned drivers why z3x not ?
This only cost 25usd in microsoft or in ftdi why not do this proper for all users that use win7/8/8.1/10 64bit ?
Old 06-10-2016, 20:26   #28 (permalink)
amrMHF's Avatar
Member: 710690
Thanks Meter: 465
i have problem with drivers when connect other box and reconnect Z3x i lost driver for box port not card driver
win 8.1 64bit
Old 09-09-2016, 07:04   #29 (permalink)
Member: 2153589
will this solve the waiting for adb problem???
Old 10-31-2016, 07:59   #30 (permalink)
Member: 99605
Thanks Meter: 57
any hope for working win10 64 bit river ? support team give us solution.
The Following User Says Thank You to siudziu For This Useful Post:
Page generated in 0.38600 seconds with 7 queries
