11-19-2016, 16:16 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Beware of people Age: 47
Member: 512551 Status: Offline Sonork: 100.1626194 Thanks Meter: 66 | B7330 unlock do by z3x UART cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Or you can 'Read User Lock' or 'Reset User Lock'. USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose USB_PHONE. 3. Type *#9090#, select: UART_HFK USB_DIAG. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Or you can 'Read User Lock' or 'Reset User Lock'. Operation: Read Codes Selected model: GT-B7330R Selected port: COM10 Qualcomm WinMobile Diagnostics 3200 Software version: 27.1 Checking phone at COM10 Reading phone info... ok Model: GT-B7330 Country code: ¿À½ºÆ®¸®¾Æ Cal date: 2010-10-01 Factory SW: B7330XXJE1 Unique number: 75600000555700 Memory phone: KBN00900HM(B7330)S Phone SN: R4YZA90886 PDA/CSC version: B7330XXJE1/B7330MAXJI1 Phone version: B7330XXJE1 Phone HW: MP 0.800 Cal date: 2010.10.22 Reading IMEI... ok IMEI: 35578700320389039 Reseting MSL... ok Bypass MSL... ok Reading codes... ok Freeze code: 81862463 NET lock: 19204649 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.1 |
The Following User Says Thank You to goodname For This Useful Post: |
