04-21-2017, 21:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: GSM-WORD
Member: 240763 Status: Offline Sonork: 100.110277 Thanks Meter: 105 | This is best tool for sumsung see inside Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-G550T Software version: 28.1 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G550T Android version: 6.0.1 Product code: SM2G550TZKATMB Phone version: G550TUVU1APF1 PDA version: G550TUVU1APF1 CSC version: G550TTMB1APF1 CSC country code: USA CSC sales code: TMB HW version: REV0.4 Phone SN: RV8HA0M73GW Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2016-06-01 RF cal date: 20161019 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: 1C 7B D6 13 06 14 CB 9A FB 11 2A D5 4D 32 72 4E Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.1 |
