10-10-2014, 21:48 | #1 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | @Blang - E1200R Network problem... Full dump or repair needed !!! As title says ... I received E1200R, which have, in place where network bars should appear, red circle crossed, and which ever software or NVM, or repair I write/flash it stays the same. No any network found. Phone came in this state to me, customer says that phone worked normally on foreign original network, and he brought it here, and someone tried to unlock it, and killed it on unlock operation (I dunno which tool used), after reviving it via flashing, that problem with network appeared. so ... the question is : is there some other area than NVM, which holds some important things, and which can cause this state ? I see that after writing NVM file, imei stays the same, so there is probably some EEprom part, protected or something, that holds some more data. Is there some way to write full dump from other working phone, or rewrite other areas that are not touched via normal flashing ? thanx for attention. b.r. Alex |
