10-01-2016, 13:22 | #2 (permalink) |
Freak Poster Join Date: May 2014 Location: East Coast
Member: 2189329 Status: Offline Thanks Meter: 8 | G920t ph2 Have you tried to patch Cert file ???? REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G920T Software version: 26.8 Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 6.0.1 Product code: SM-G920TZKATMB Phone version: G920TUVS4EPH2 PDA version: G920TUVS4EPH2 CSC version: G920TTMB4EPH2 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58G31EA5DR Modem board: SHANNON333 RF cal date: 20150319 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.26.8 |
10-02-2016, 08:21 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2011 Location: APPEL
Member: 1707492 Status: Offline Thanks Meter: 606 | bro everything is ok my phone work good ...you need cert ?? z3x not support red cert 6.0.1 whan you try to red cert show error 9 must need sboot downgrade ....im jest done unlock |
10-06-2016, 02:01 | #5 (permalink) | |
Registered User Join Date: Apr 2010
Member: 1290061 Status: Offline Thanks Meter: 61 | Quote:
11-21-2016, 20:11 | #10 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2105654 Status: Offline Thanks Meter: 7 | CHIMERA DID NOT WORK Chimera Mobile Phone Utility version: 12.08.1138 @ 2016-11-21 Printing phone history Root/Unroot 11/21/2016 6:52:58 PM [Rooting phone started] Checking custom root image... This model is not available custom root image. Unable to root. Retry or root manually. Click here to download rooting tools. Finished at local time: [11.21.16 13:54:26] WorkID: 1XXXXXXXXX BUT CF AUTO R... WORKS.....! PD6 FOR PH2 USE IT ON YOUR OWN RISK . THANKS |
