11-07-2015, 12:08 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: earth
Member: 570373 Status: Offline Thanks Meter: 236 | SM-G313HZ Flash Error [Answered] Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x3C957830 Searching USB Flash Interface... detected COM28 Setup connection... OK Set PIT file... Error Done with Samsung Tool v.19.1 try 4 files and 1 pack file & pit files flash files are work other phone test. in downloading mode pro name: sm-g313hz_vn |
11-07-2015, 17:28 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
if same problem - then can be problem with hardware. emmc or other things. | |
The Following User Says Thank You to blang For This Useful Post: |
11-19-2018, 11:10 | #5 (permalink) |
Junior Member Join Date: Aug 2014 Location: passi city iloilo
Member: 2245043 Status: Offline Thanks Meter: 3 | samsung g313hz_vn firmware are same model as samsung g313hz firmware use i9000 cable that came with z3x box.. make sure you battery is charged... connect it via uart port of yuor box..its tested |
