09-12-2011, 17:02 | #1 (permalink) |
Freak Poster Join Date: Oct 2002
Member: 17246 Status: Offline Thanks Meter: 0 | Box will not connect very frustrating Card Not Found waiting for connection All the correct drivers are there as i used it the other week!! In shell it states card not connected status: Psur0ur1ur2cdnpsb use wizard for card recovery Try to use wizard but says it cant update as card not found! Anyone help as this is very frustrating!! |
09-12-2011, 18:50 | #2 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Check how it's recognized in device manager, sometimes drivers are overwritten by an other app. I had same problem and I opened my box to clean the sim card, and it started back, but maybe it's just a coincidence. |
09-12-2011, 19:10 | #3 (permalink) |
Member: 17246 Status: Offline Thanks Meter: 0 | thanks will try that, what should it appear as in device manager? want to make sure installed correct (althou like said worked fine other week) its annoyin as putting me behind my work. I am running in Xp |
09-12-2011, 23:58 | #4 (permalink) | |
Freak Poster Join Date: May 2009 Location: Wales
Member: 1035679 Status: Offline Thanks Meter: 62 | Quote:
Uploaded with ImageShack.us hope this helps i had the same with my box for the first 8 months (some times connect some times not) when i noticed if i moved the box or tap the top of the box or touch the card in the slot it would work (something loose inside) when i took the back off and run some tests every time i touched the card it would connect (poor connection with reader) my fix was a piece of plastic pressed in-between the box and the card to apply a small pressure on the card against the reader it has not failed to connect for about 2 years now and still going strong BR | |
The Following User Says Thank You to wed1 For This Useful Post: |
09-13-2011, 00:40 | #5 (permalink) | |
Freak Poster Join Date: Sep 2011 Location: In The World Of ALLAH & RASOOL Age: 33
Member: 1647655 Status: Offline Sonork: 100.1640928 Thanks Meter: 50 | Quote:
I HAD SAME PROBLEM FEW WEEKS BACK SO WHAT I DONE WAS UNINSTALL ALL THE Z3X BOX DRIVERS THEN REBOOT YOUR SYSTEM INSTALL IT CONNECT YOUR BOX TO INSTALL DRIVERS ONLY WHEN DONE REBOOT AGAIN IT WILL WORK. IT WORKED FOR ME SO GIVE A GO WORTH A TRY :d | |
The Following User Says Thank You to ZJ. For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-27-1999 09:36 |
I will finished Dongle for Nokia WinTesla | MyKy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-14-1999 22:47 |
