02-22-2019, 19:27 | #1 (permalink) |
Insane Poster Join Date: Mar 2013 Location: In the END of EU or start )
Member: 1896562 Status: Offline Thanks Meter: 2 | bricked G928FXXS5CR SM-G928F After flash many times,allways same error. "device does not have DRK,please install DRK first. Press any button,then it goes to recovery. Then error dm-verity come with failed code : 0x02. If try to flash TWRP, not sucefull by error "Custom Binary (recovery) Blocked by FRP lock. in green. Cant find combination file for B5,any solution Mr.Blang? |
02-24-2019, 13:31 | #7 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 432 | Quote:
If reset frp by UFS (uart) does not work on phone because G928FXXS5CR, and there is no binary 5 combination, tens uma bronca aí nas mãos.... | |
02-24-2019, 13:52 | #10 (permalink) |
Member: 478535 Status: Offline Thanks Meter: 432 | binary 5 stock fw for s6e+ exist since mid last year. If easy firmware and others similar service does not have, i would not hold my breath waiting for bin 5 combination fw. |
02-24-2019, 14:39 | #11 (permalink) |
Member: 1896562 Status: Offline Thanks Meter: 2 | Fixed. 1-not correct sequence keys for remove FRP, by UART mode,after right combination of keys,FRP as removed. 2- Flash CF auto root. 3- after boot,enable OEM unlock. Working ok,thanks to all. BR |
05-09-2019, 19:11 | #14 (permalink) |
Member: 478535 Status: Offline Thanks Meter: 432 | When you start the uart frp (ufs) remove, z3x wil tell you what keys to hold wile doing the operation. For this u use reset frp ufs function in unlock tab! Code: To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. (z3x box com) 4. Press 'Reset FRP UFS' and follow the instructions in program Done with Samsung Tool PRO v.36.1 |
