04-14-2017, 10:54 | #1 (permalink) |
Insane Poster Join Date: May 2003 Location: Australia/Sydney
Member: 28653 Status: Offline Thanks Meter: 5 | Bypass FRP s7 edge February 2017 security I am looking for the solution to bypass S7 edge running on nougat 7 with latest security patch. I have tried realterm method but it doesn't work. It wont let me create a new ID from google account manager. It always says error. Regards. |
The Following User Says Thank You to kingofcellulars For This Useful Post: |
04-14-2017, 10:58 | #2 (permalink) |
Insane Poster Join Date: Dec 2016
Member: 2662087 Status: Offline Thanks Meter: 17 | Downgrade to 6.0.1 after that it's easy to remove FRP, then you can upgrade to 7.0 after removing it. Had one yesterday until until I was forced to downgrade. Sent from my Hisense F20 using Tapatalk |
The Following User Says Thank You to PHONESONLY For This Useful Post: |
04-14-2017, 10:59 | #3 (permalink) | |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | what an error you have Quote:
always press:> GSM-Forum - Search Forums before post Follow the rules. http://forum.gsmhosting.com/vbb/f62/...rules-1591101/ BestRegards, MajeedGsm. | |
The Following User Says Thank You to appsworlmardan For This Useful Post: |
04-14-2017, 13:53 | #4 (permalink) |
Major Poster Join Date: Sep 2013 Location: Ft. Worth, TX
Member: 2031642 Status: Offline Thanks Meter: 8 | I flashed the Eng boot.img to enable ADB and then used a couple of commands. Let me know if you want the files if you don't feel like downgrading it's pretty simple Sent from my SM-G920T using Tapatalk |
The Following 3 Users Say Thank You to wdjones817 For This Useful Post: |
04-14-2017, 14:10 | #5 (permalink) |
Member: 2662087 Status: Offline Thanks Meter: 17 | Wdjones817;12450068 I would like to have those files 📁 for future use in case I have another customer bringing in that phone Sent from my Hisense F20 using Tapatalk |
04-14-2017, 21:52 | #7 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | Try this NO Box method: http://forum.gsmhosting.com/vbb/f453...moval-2180813/ DO NOT FORGET TO CLICK ON THE THANKS BUTTON |
The Following User Says Thank You to GalaxyVibe For This Useful Post: |
04-14-2017, 23:29 | #8 (permalink) | |
Member: 2031642 Status: Offline Thanks Meter: 8 | Quote:
https://drive.google.com/file/d/0B_d...w?usp=drivesdk | |
04-15-2017, 00:55 | #9 (permalink) |
Member: 28653 Status: Offline Thanks Meter: 5 | I have tried downgrading the firmware to marshmallow but after successful downgrading phone stuck in recovery mode. I have tried 10 different versions all the same tried factory reset, cache wipe no luck at all. |
04-15-2017, 01:39 | #11 (permalink) | |||
Member: 28653 Status: Offline Thanks Meter: 5 | Quote:
Quote: Quote:
Regards | |||
04-15-2017, 07:11 | #13 (permalink) | |
Member: 2662087 Status: Offline Thanks Meter: 17 | Quote:
Sent from my Hisense F20 using Tapatalk | |
04-15-2017, 07:17 | #14 (permalink) | |
Sent from my SM-G920T using Tapatalk | |
04-17-2017, 03:13 | #15 (permalink) |
Member: 28653 Status: Offline Thanks Meter: 5 | @PHONESONLY I am not doing anything wrong. Whatever you guys telling me i am doing the exactly same steps. I have tried that too TWRP recovery failed and on the phone screen it says " FRP LOCK IS ENABLED" so clearly we have to get rid of that first. @wdjones817 Yes i did try that it was stuck on S7 edge logo screen just to try my luck i ran the bat file but no luck with it. Next time if you do the latest FRP disabled just have a look inside about if it says 1 February 2017 or not. Regards. |
