Old 03-31-2011, 21:37   #1 (permalink)
Anand Sharma's Avatar
Member: 1012744
C3053 Strange Problem SOLVED By z3x ......
Today i have faced a strange problem i got a handset in hand SAMSUNG C.3053 with the strange problem.no menu shown like lg3500 without scr file.
and i got the solution.
do the thing...
1. Full Erase phone.
2.Write firmware with the same file name for me it was
CODE_C3053DDIF2_binary.s3
C3053ODDIE2.csc india language.
3.Repair Otp imei.
4.Repair Custom Imei.
5. And finaly Direct unlock.
now the phone is ok .
br.
cool.anand
HERE IS LOGS.
Selected model: C3053
Selected com port: COM7
Selected speed port: 460800
Phone must be OFF with battery
Please, connect phone and press shortly power button
Syncing phone... OK
Sending loader 1... OK
Syncing phone... OK
Sending loader 2... OK
Syncing phone... OK
Syncing phone... OK
Flash ID: 890000007E88
Syncing phone... OK
Erase full flash... OK
Elapsed time: 300 second, sw ver: 3.5.0008
Decode *.s3 file - please wait
segments 9
segment 1 20300000 25322656 byte
segment 2 2001E000 180 byte
segment 3 20016000 26012 byte
segment 4 20000000 100 byte
segment 5 20078000 1132768 byte
segment 6 2000C000 21412 byte
segment 7 20058000 56 byte
segment 8 20058138 16924 byte
segment 9 2003803C 36508 byte
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Sending *.s3 file... OK
Sending *.cts or *.csc file...
Detected file - > 87
Format FFS - wait... OK
Send content - wait... OK
Elapsed time: 1216 second, sw ver: 3.5.0008
Phone must be ON!
Entering TestMode... OK
Start repair IMEI......
SW: C3053DDIF2
IMEI: 00000000000000
Cal Data corrupt or erased - use repair OTP function !
Repair - false
Elapsed time: 30 second, sw ver: 3.5.0008
Phone must be ON!
SW: C3053DDIF2
Repair - false
Elapsed time: 9 second, sw ver: 3.5.0008
Start generation to file...
Encode *.s3 - wait... OK
EEP saved to file-> C:\Program Files\Z3X\Samsung\All\C3053_RV3S632848P_.sre
Phone must be ON!
Start calibrate NVM
Calibrate NVM field - fail
Calibrate NVM - Ok
Field IMEI - not set ! Use button "Custom" for repair
Repair OTP - ok
Elapsed time: 69 second, sw ver: 3.5.0008
Phone must be ON!
SW: C3053DDIF2
MSL DEACTIVATED - TRUE
Imei store to RAM
Imei store to flash
Repair IMEI - ok
Elapsed time: 13 second, sw ver: 3.5.0008
Phone must be ON!
Start unlock........
SW: C3053DDIF2
IMEI: 35381603314795
Set default customer - fail
Unlock - fail
Unlock - false
Elapsed time: 23 second, sw ver: 3.5.0008
Phone must be ON!
SW: C3053DDIF2
NET and SIM lock - deactivated
Phone password change into -> 00000000
Unlock - ok
Old 04-01-2011, 11:07   #2 (permalink)
Registered User
Member: 801757
Sonork: BB17
good job brother................ I also
Selected com port: COM5
segments 9
segment 1 20000000 100 byte
segment 2 20300000 27548508 byte
segment 3 2001E000 180 byte
segment 4 20016000 6248 byte
segment 5 20078000 1135276 byte
segment 6 2000C000 21404 byte
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Elapsed time: 1127 second, sw ver: 3.5.0007
Old 04-02-2011, 06:56   #3 (permalink)
Member: 1306699
Sonork: GC
if i use CODE_C3053DXK1.s3
what csc i need sir ?
The Following User Says Thank You to Stress Boyz For This Useful Post:
Old 04-03-2011, 07:21   #4 (permalink)
Member: 710525
do the thing...
3.Repair Otp imei.
br.
cool.anand
HERE IS LOGS.
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
segments 9
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Phone must be ON!
SW: C3053DDIF2
Repair - false
Phone must be ON!
SW: C3053DDIF2
Repair - false
Phone must be ON!
Start calibrate NVM
Calibrate NVM - Ok
Repair OTP - ok
Phone must be ON!
SW: C3053DDIF2
Imei store to RAM
Imei store to flash
Repair IMEI - ok
Phone must be ON!
SW: C3053DDIF2
Unlock - fail
Unlock - false
Phone must be ON!
SW: C3053DDIF2
Unlock - ok
the csc file failed sir ?
what should i do ?
Old 04-03-2011, 09:17   #5 (permalink)
Member: 710525
Selected com port: COM4
segments 9
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
FIOP - false
Send cts - fail
Elapsed time: 1213 second, sw ver: 3.5.0009
Old 04-03-2011, 15:35   #6 (permalink)
Member: 1012744
Originally Posted by Stress Boyz View Post
if i use CODE_C3053DXIK1.s3
you should try with
C3053OLAJC1 csc download from support.
wbr
cool.anand
The Following User Says Thank You to Anand Sharma For This Useful Post:
Old 04-03-2011, 15:37   #7 (permalink)
Member: 1012744
segments 9
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
Syncing phone... OK
FIOP - false
Send cts - fail
First u post here about the phone
which file using u r ?
code ?
csc ?
Old 04-04-2011, 11:29   #8 (permalink)
Member: 710525
i use same like u sir
Old 04-04-2011, 14:27   #9 (permalink)
Member: 1012744
Full erase first then flash again. do the same.
Old 04-05-2011, 10:23   #10 (permalink)
Member: 1306699
Sonork: GC
is there backup section sir ?
erase can make imei 00000 or 12345 ???
Old 04-11-2011, 17:50   #11 (permalink)
Member: 1012744
Do not worry u can repair eeprom and restore imei.
Old 04-14-2011, 14:38   #12 (permalink)
Member: 710525
now my phone is dead
omg
Syncing phone... OK
FIOP - false
Send cts - fail
Old 06-03-2012, 05:13   #13 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
omg
Syncing phone... OK
FIOP - false
Send cts - fail
check here and solved .
Samsung c3053 successfully flash done without any error (Gide) .
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.38416 seconds with 11 queries
