07-27-2013, 10:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: istanbul - turkey
Member: 1739390 Status: Offline Sonork: 100.1623876 Thanks Meter: 5 | c3300k software I tried software for many devices on this windows past but now this message is shown : |
07-27-2013, 13:54 | #2 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | press "volume up" + "lock" and connect USB cable to phone and give drive. driver support 100% |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
07-27-2013, 14:06 | #3 (permalink) |
Member: 1739390 Status: Offline Sonork: 100.1623876 Thanks Meter: 5 | yes I pressed "volume up" + "lock" and this trouble occured on past I made the same method and success on software but now I make the same methode but no success please help |
07-27-2013, 14:11 | #4 (permalink) |
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | hi use to Samsung c3303 Champ Flash/Firmware without box use usb cable Prepare the Phone Driver for Flashing. 1. Turn OFF Phone. 2. Connect MicroUSB to Champ. 3. Press Volume Down + Lock key then connect USB Cable to PC 4. Install driver (Driver can be found on C3300K_Flash_loader_7.4.4_SSG_v0.5 folder, 52xdfu)(Manual install it using device manager) When installed, get ready. Re flashing 1. Run Flash loader 7.4.4_SSG_v0.5.exe 2. Click SET MODEL -> Select C3300_LIBRE_Setting_v02.mdl 6. Click Start 7. Turn OFF Phone. 8. Connect MicroUSB to Champ. 9. Press Volume Down + Lock key then connect USB Cable to PC 10. Wait the flashing finished. (During the Flashing, your phone is off, then when the flashing is finish, you can see the your phone is charging. 11. Remove from USB. Turn on the Phone, Check if success, -if failed, try nyu ulit ang mga steps. http://www.4shared.com/file/PNYp0EsM/C3303KJPJI2.html http://www.4shared.com/file/8S8zLiSd...7.4.4_SSG_v0.5 3. MicroUSB 4. C3303k Samsung Champ Phone 5. Prepare Phone Driver |
07-28-2013, 10:20 | #5 (permalink) |
Member: 1739390 Status: Offline Sonork: 100.1623876 Thanks Meter: 5 | thank for reply I know this way ,but I sufferd from this trouble in all samsung mobiles by z3x I want to repair this trouble in z3x box thanks for reply |
