06-02-2013, 10:37 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: in the corner Age: 35
Member: 285779 Status: Offline Thanks Meter: 49 | C3303i flashing failed Selected model: C3303 Selected com port: COM3 Selected speed port: 921600 Not support uart algo for this phone Download - ok Elapsed time: 1 second, sw ver: 3.5.0040 |
06-02-2013, 10:44 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2012 Location: bangladesh
Member: 1850093 Status: Offline Sonork: 100.1627469 Thanks Meter: 339 | press "volume up" + "lock" and connect USB cable to phone press frmware button here is log Selected model: C3303 Selected com port: COM1 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Sending part LCDACT: Erasing... OK Sending... OK Sending part MAIN: Erasing... OK Sending... OK Sending part DSP: Erasing... OK Sending... OK Sending part ROOT: Erasing... OK Sending... OK Sending boot sector: Erasing... OK Sending... OK Sending TFS... OK Sending CSC... OK Download - ok Elapsed time: 826 second, sw ver: 3.5.0021 |
The Following User Says Thank You to gsmnsd For This Useful Post: |
06-02-2013, 11:04 | #4 (permalink) |
Member: 285779 Status: Offline Thanks Meter: 49 | its detected now . thnakyou another problem is when the box is deteccted with the phone , the error messega show : the application has encountered a problem . we are sorry for the inconvenience . __________________________________________________ ___________________ Access violation at address 007B4A66 in module 'Samsung.exe'. Read of address 00000000. |
06-02-2013, 21:21 | #7 (permalink) | ||
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | change main cable and make sure you have installed net framework, also try with low ver.. and post result.. Quote:
check section before post , Thanks for understanding. | ||
