03-14-2013, 12:12 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: sa bahay namin Age: 42
Member: 392861 Status: Offline Thanks Meter: 46 | c3312 unlock problem pls help.. Selected com port: COM4 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM107) Deactivate MSL - fail Unlock - fail Elapsed time: 6 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3312 Selected com port: COM4 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Sending...C3312XXLA5_psi.fls (psi.fls) Writing ... OK Sending...C3312XXLA5_slb.fls (slb.fls) Writing ... OK Sending...C3312XXLA5_BSY.fls (CATFISH.fls) Writing ... OK Writing ... OK Sending...C3312XXLA5_CDS.fls (CATFISH.fls) Writing ... OK Sending...C3312OXELA3_CSC.dffs (temp_GT-C3312_OXE.dffs) Writing ... OK Flash FLS - ok Elapsed time: 148 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3312 Selected com port: COM4 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM107) Deactivate MSL - fail Unlock - fail Elapsed time: 25 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- i all ready try this file C3312DXLD1_OLALD1 C3312DXLH1_OLALE1 C3312XXLA5_OXELA3 |
03-15-2013, 03:28 | #3 (permalink) |
Member: 392861 Status: Offline Thanks Meter: 46 | same problem Selected model: C3312 Selected com port: COM4 Selected speed port: 115200 Attention !!! Use this operation after flashing phone Search diag port... OK (COM107) Deactivate MSL - fail Unlock - fail Elapsed time: 33 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
03-15-2013, 04:16 | #5 (permalink) | |
Freak Poster Join Date: Apr 2012
Member: 1751502 Status: Offline Sonork: abc Thanks Meter: 18 | Quote:
1,press firmware button 2,connect phone pressing volume down key with usb cable without battery 3,wait for flashing after full flash connect phnoe with usb cable to other ports on your computer connecting time phone must be on check the com port window on z3x and select the port where you connect the phone select it then press the direct unlock on z3x phone must unlock now | |
03-15-2013, 04:18 | #6 (permalink) | |
Member: 392861 Status: Offline Thanks Meter: 46 | Quote:
i flash this phone many times before do i need to flash the phone every time i unlock? how can i deactivate MSL? maybe this phone is deferment from the other phone posted in this forum successfully unlock via flash then unlock now i flash again then unlock again Selected model: C3312 Selected com port: COM4 Selected speed port: 115200 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Sending...C3312XXLA5_psi.fls (psi.fls) Writing ... OK Sending...C3312XXLA5_slb.fls (slb.fls) Writing ... OK Sending...C3312XXLA5_BSY.fls (CATFISH.fls) Writing ... OK Writing ... OK Sending...C3312XXLA5_CDS.fls (CATFISH.fls) Writing ... OK Sending...C3312OXELA3_CSC.dffs (temp_GT-C3312_OXE.dffs) Writing ... OK Flash FLS - ok Elapsed time: 140 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3312 Selected com port: COM4 Selected speed port: 115200 Attention !!! Use this operation after flashing phone Search diag port... OK (COM107) Deactivate MSL - fail Unlock - fail Elapsed time: 29 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- | |
03-15-2013, 04:28 | #7 (permalink) |
Member: 392861 Status: Offline Thanks Meter: 46 | men pls read my fist post and logs i have no problem in flashing my problem is why it cant be deactivate msl so it can unlock to clear that i flash it again and again and again i flash it again and and again Selected model: C3312 Selected com port: COM4 Selected speed port: 115200 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Sending...C3312XXLA5_psi.fls (psi.fls) Writing ... OK Sending...C3312XXLA5_slb.fls (slb.fls) Writing ... OK Sending...C3312XXLA5_BSY.fls (CATFISH.fls) Writing ... OK Writing ... OK Sending...C3312XXLA5_CDS.fls (CATFISH.fls) Writing ... OK Sending...C3312OXELA3_CSC.dffs (temp_GT-C3312_OXE.dffs) Writing ... OK Flash FLS - ok Elapsed time: 140 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3312 Selected com port: COM4 Selected speed port: 115200 Attention !!! Use this operation after flashing phone Search diag port... OK (COM107) Deactivate MSL - fail Unlock - fail Elapsed time: 29 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3312 Selected com port: COM4 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Sending...C3312XXLA5_psi.fls (psi.fls) Writing ... OK Sending...C3312XXLA5_slb.fls (slb.fls) Writing ... OK Sending...C3312XXLA5_BSY.fls (CATFISH.fls) Writing ... OK Writing ... OK Sending...C3312XXLA5_CDS.fls (CATFISH.fls) Writing ... OK Sending...C3312OXELA3_CSC.dffs (temp_GT-C3312_OXE.dffs) Writing ... OK Flash FLS - ok Elapsed time: 132 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3312 Selected com port: COM4 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM107) Deactivate MSL - fail Unlock - fail Elapsed time: 6 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
03-15-2013, 04:30 | #8 (permalink) | |
03-15-2013, 04:59 | #9 (permalink) | |
that's what i do, flash the phone with or without battery press vol down then connect cable wait until flashing is done, power on the phone wait until computer recognize the port select diagnostic port or even with or without selecting port it will automatically find it, press unlock but always fail i try in my other computer but same result Selected model: C3312 Selected com port: COM4 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Sending...C3312DXLD1_psi.fls (psi.fls) Writing ... OK Sending...C3312DXLD1_slb.fls (slb.fls) Writing ... OK Sending...C3312DXLD1_BSY.fls (CATFISH.fls) Writing ... OK Writing ... OK Sending...C3312DXLD1_CDS.fls (CATFISH.fls) Writing ... OK Sending...C3312OLALD1_CSC.dffs (temp_GT-C3312_OLA.dffs) Writing ... OK Flash FLS - ok Elapsed time: 158 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3312 Selected com port: COM4 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM124) Deactivate MSL - fail Unlock - fail Elapsed time: 6 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- | |
03-15-2013, 05:19 | #10 (permalink) | |
this port not 4 cheq com port device manager and z3x com port slect com not port 4 & do direct unlock | |
03-15-2013, 05:32 | #11 (permalink) |
Member: 392861 Status: Offline Thanks Meter: 46 | com4 is port of z3x box which is not need for flashing because i will automatically detect after press vol down and cable when i unlock phone is on i select com107 and in my other computer com124 even not select port it will automatically find it |
