06-18-2011, 07:52 | #1 (permalink) |
Major Poster Join Date: Feb 2011 Location: Serbia
Member: 1506502 Status: Offline Thanks Meter: 1 | C3500 unlock not solved Phone is looking for freeze code, here is the log: Selected model: C3500 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500XXKA3 Phone CSC: C3500OXFKA2 Phone BT ADDR: 8C71-F8-75E748 Phone IMEI: 35402804033064 Deactivated MSL - FAIL Elapsed time: 23 second, sw ver: 3.5.0021 This is all i get Please help. |
06-18-2011, 10:49 | #2 (permalink) | |
Product Supporter Join Date: Aug 2007
Member: 561932 Status: Offline Thanks Meter: 168 | Quote:
The Following User Says Thank You to alex999_ For This Useful Post: |
06-23-2011, 12:25 | #5 (permalink) |
Insane Poster Join Date: Jun 2005 Location: Serbia Age: 53
Member: 152327 Status: Offline Thanks Meter: 30 | Selected model: C3500 Selected com port: COM6 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 35402804xxxxxx Phone SW -> C3500XXKA3 Langpack-> Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom Phone HW -> MP 0.600 Phone BT ADDR -> 8C71-F8-75E5CF [FREEZE LOCK]:26994370, [NET LOCK]:28848800, [SIM LOCK]:00000000, [PHONE LOCK]:00000000, [SP LOCK]:00000000, Read Info - ok Elapsed time: 88 second, sw ver: 3.5.0021 work with usb... |
07-21-2011, 11:25 | #8 (permalink) | |
No Life Poster Join Date: Mar 2008
Member: 725834 Status: Offline Thanks Meter: 921 | Quote:
07-10-2012, 12:44 | #10 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1782356 Status: Offline Thanks Meter: 0 | i can't read codes from C3500, says Selected model: C3300K Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500AIKC3 Phone CSC: C3500TIMKC4 Phone BT ADDR: 2013-E0-8359C1 Phone IMEI: 3540280****66 Deactivated MSL - FAIL Elapsed time: 31 second, sw ver: 3.5.0038 ----------------------------------------------------------- |
09-26-2012, 21:25 | #12 (permalink) |
Freak Poster Join Date: Mar 2010 Location: Behind your back
Member: 1258305 Status: Offline Thanks Meter: 46 | Ok people here we go. First of all you not need battery in phone if you wanna do this. Second When you select model C3500 and go in windows for work you will see you have options so check Flash mode and check USB afther that click direct unlock and then hold VOLUME DOWN and LOCK KEY and put Micro USB in phone. Well Done your phone is unlocked. Regards, LiLSaint |
10-26-2012, 13:58 | #13 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1617200 Status: Offline Thanks Meter: 0 | Phone HW -> MP 0.600 Phone BT ADDR -> 8C77-12-E162A6 Read Info - ok Elapsed time: 75 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3500 Selected com port: COM3 Selected speed port: 921600 Press "1" + "3" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 150 second, sw ver: 3.5.0040 Good morning, I'm trying to unlock this device as the above but not unlock. presciso help to see where I am going wrong or not this unlocks it. |
10-26-2012, 19:02 | #15 (permalink) |
Member: 1617200 Status: Offline Thanks Meter: 0 | I did not know if true, do this procedure with or without end chip, and do not quite understand this sequence, do the reset after imput this code not quite understand what this code is, or it refers to this last setting. thank you |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
