Old 06-18-2011, 07:52   #1 (permalink)
Member: 1506502
Red face C3500 unlock not solved
Ok, i have tried everything to unlock this phone, but i failed.
Phone is looking for freeze code, here is the log:
Selected model: C3500
Selected com port: COM4
Selected speed port: 921600
Please, connect phone and press power button 3 seconds
Phone Detected
Use automatic parameters
Phone in TAT MODE
Phone SW: C3500XXKA3
Phone CSC: C3500OXFKA2
Phone BT ADDR: 8C71-F8-75E748
Phone IMEI: 35402804033064
Deactivated MSL - FAIL
Elapsed time: 23 second, sw ver: 3.5.0021
This is all i get
Please help.
Old 06-18-2011, 10:49   #2 (permalink)
Member: 561932
Thanks Meter: 168
Phone Detected
Phone in TAT MODE
This is all i get
Please help.
Set model as C3222 and press read code.
The Following User Says Thank You to alex999_ For This Useful Post:
Old 06-20-2011, 08:08   #3 (permalink)
Member: 1506502
Same log again...
Old 06-20-2011, 10:31   #4 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
Same log again...
i post already in forum. if someone have problem contakt with me in sonork.
Old 06-23-2011, 12:25   #5 (permalink)
Member: 152327
Thanks Meter: 30
Selected com port: COM6
Press "volume up" + "lock" and connect USB cable to phone
Connect to control pipe... OK
Processor ID -> 0A33
Sending loader... OK
Connect to write pipe... OK
Connect to read pipe... OK
Damping... OK
Phone master IMEI -> 35402804xxxxxx
Phone SW -> C3500XXKA3
Langpack-> Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom
Phone HW -> MP 0.600
Phone BT ADDR -> 8C71-F8-75E5CF
[FREEZE LOCK]:26994370,
[NET LOCK]:28848800,
[SIM LOCK]:00000000,
[PHONE LOCK]:00000000,
[SP LOCK]:00000000,
Read Info - ok
Elapsed time: 88 second, sw ver: 3.5.0021
work with usb...
Old 07-08-2011, 11:12   #6 (permalink)
EL_DIABLO's Avatar
Member: 13116
Thanks Meter: 40
You can unlock by using C3300k RJ45 cable,Use the new version v3.5.0025
Old 07-09-2011, 07:17   #7 (permalink)
Member: 1506502
i did it allready, thanks anyway.
sorry for not posting earlier
Old 07-21-2011, 11:25   #8 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 921
Phone Detected
press power button long time,
Old 01-19-2012, 15:32   #9 (permalink)
cavalierks's Avatar
Member: 1523083
Sonork: 100.1609029
Thanks Meter: 141
worked for me thank you ...::
Old 07-10-2012, 12:44   #10 (permalink)
Member: 1782356
i can't read codes from C3500, says
Selected model: C3300K
Selected com port: COM3
Phone Detected
Phone in TAT MODE
Phone SW: C3500AIKC3
Phone CSC: C3500TIMKC4
Phone BT ADDR: 2013-E0-8359C1
Phone IMEI: 3540280****66
Elapsed time: 31 second, sw ver: 3.5.0038
Old 08-01-2012, 17:04   #11 (permalink)
Fys
Member: 54294
Thanks Meter: 18
Old 09-26-2012, 21:25   #12 (permalink)
LiLSaint's Avatar
Member: 1258305
Thanks Meter: 46
Ok people here we go.
First of all you not need battery in phone if you wanna do this.
Second When you select model C3500 and go in windows for work you will see you have options so check Flash mode and check USB afther that click direct unlock and then hold VOLUME DOWN and LOCK KEY and put Micro USB in phone.
Well Done your phone is unlocked.
Regards,
LiLSaint
Old 10-26-2012, 13:58   #13 (permalink)
Member: 1617200
Phone BT ADDR -> 8C77-12-E162A6
Read Info - ok
Elapsed time: 75 second, sw ver: 3.5.0040
Press "1" + "3" and connect USB cable to phone
Damping... OK
Erasing... OK
Sending... OK
Unlock - ok
If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000#
Elapsed time: 150 second, sw ver: 3.5.0040
Good morning, I'm trying to unlock this device as the above but not unlock. presciso help to see where I am going wrong or not this unlocks it.
Old 10-26-2012, 14:06   #14 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 444
Did you do this to finish procedure ?
Old 10-26-2012, 19:02   #15 (permalink)
Member: 1617200
I did not know if true, do this procedure with or without end chip, and do not quite understand this sequence, do the reset after imput this code not quite understand what this code is, or it refers to this last setting.
thank you
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.23754 seconds with 9 queries
