09-08-2016, 09:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: türkiye Age: 59
Member: 7114 Status: Offline Thanks Meter: 51 | c3595 flashed but 'c3595' flashing blinking Operation: Flash Selected model: GT-C3595 Software version: 26.6 Load model info... OK Loading BIN PTT file... OK Reconnect battery and connect phone to USB cable Phone detected Checking device descriptions... OK Link type set to USBH Reading OTP register... OK OTP register: 00000000 Unprotected device detected Reading product ID... OK Product ID: 0x A627441CED096AD Reading SCROM version... SCROM Version - PNX6729 v. 1.10 Chipset Version - 3C11 Downloading Loader in Internal RAM... OK Wait for device... OK Checking device descriptions... OK Loader verison... 7.5.16 Nand Flash memory SSG_K522H1HACA-A060 detected Flash memory parameters Capacity params: 2 Datawidth - 2048 Block number - 64 Block size - 0 Buffer prog. Timing params: 2 ms erase block time - 250 us write buffer time Send Loader and NAND Flash Parameters... Loader parameters Write Test flash params: 0x0 Test Address - 0 Test size Buffer params: 3 Buffer type - 134217728 Buffer size - 32768 Tansfert size - 32768 Tansfert RAW size Bad Block params: 42 Bad block reservoir size SW Boot compatible Get First Block... OK Prepare First Block... OK Partition Table in Firstblock needs to be updated from SW Boot file FirstBlock Must Be updated Erase First Block... OK Set Partition Params... OK Downloading FirstBlock in Flash... OK Init Bad Block Managment... OK Send Verify Cmd... OK Erasing Partition_1... OK Erasing Partition_2... OK Erasing Partition_3... OK Erasing Partition_4... OK Check Protected Device... OK Programming Partition_1 Prepare CRC32... OK Set Partition Params... OK Download Partition_1 'IMAGE'... OK Check CRC32... OK Programming Partition_2 Prepare CRC32... OK Set Partition Params... OK Download Partition_2 'LCDACT'... OK Check CRC32... OK Programming Partition_3 Prepare CRC32... OK Set Partition Params... OK Download Partition_3 'MAIN'... OK Check CRC32... OK Programming Partition_4 Prepare CRC32... OK Set Partition Params... OK Download Partition_4 'PAGED'... OK Check CRC32... OK Update RCB... OK Flashing done (time - 00:01:06) Done with Samsung Tool PRO v.26.6 |
