03-07-2010, 11:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | C5212 JAVA installaton help needed;) I need help installing JAVA on new samsung phones,atm i need C5212.I make JAD and JAR but when trying to install it says "Invalid JAD file".I had this problem with 3G phones like F480 but this solved in the folling thread,please help. |
03-07-2010, 18:34 | #2 (permalink) |
Member: 115172 Status: Offline Thanks Meter: 212 | Now i'd leave it here for those who may be in trouble like me.Copy JAR & JAD files to "Other" folder in MMC card.But usually you get errors while installing files larger than 400KB,do as following manual and have fun,don't forget say "Thanks" Installation of JAVA games/ softwares on Samsung C5212 is really simple and straightforward. Unlike many Samsung mobiles, you just need to place JAR and JAD files in the SAME folder of your mobile ( Other files folder of internal memory or in the memory card). Then select JAD file and select "Options/ Install". This will start the installation process. By default, there is a limit of 400 KB for maximum JAR file size and you can't install JAR file bigger than 400 KB. If you try to install such files, you will see "JAR file is over max size" pop-up message error. To increase the maximum JAR file size limit, follow this simple procedure: Enter this code in standby mode: *#52828378# You will see "JAVA Test Menu" screen. Select option # 6 which is "OTA Test". Here you can see "Maximum JAR size (KB) which is 400 KB by default. Just enter your own value like 2048 KB. Press "Save" and exit from it. Now you can install JAR file of upto 2 MB size. Keep in mind that your new setting (2MB) will change back to default value (400 KB) if you RESTART your mobile. So, this is just a temporary setting but works perfectly to install large JAR files. Note: You can set 4MB (4096 KB) limit for JAR files but it is safe to set this limit to 2MB and this 2MB limit is enough for most of JAVA softwares keeping in mind that "Games and more" JAVA folder size is only 4 MB. |
The Following User Says Thank You to meisam For This Useful Post: |
03-10-2010, 14:27 | #3 (permalink) | |
Insane Poster Join Date: Jul 2006 Location: india
Member: 319407 Status: Offline Thanks Meter: 17 | Quote:
Last edited by zoni; 03-10-2010 at 14:28. Reason: UNSUPPORTED FILE TYE WHEN "options/ install". | |
Java Calculator Help! | norbx | Java, iOS, Android, Symbian development | 1 | 07-12-2004 09:22 |
java question...help | usong725 | x1x to x45/x50 | 3 | 04-29-2004 21:18 |
java question...help | usong725 | x1x to x45/x50 | 0 | 04-23-2004 02:34 |
Java enabler help for c56 with generic cable | louiedog | E-Gold Based Phones | 0 | 10-28-2003 19:44 |
t720i java games help plz | falcon65 | Motorola P2k | 3 | 10-15-2003 22:21 |
