01-25-2015, 13:28 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2136362 Status: Offline Thanks Meter: 31 | Which cable to use for android? Hence need help of experts... I use normal usb cable, but samsung com port not shown in the device manager. In the phone Samsung S7562, I tried the following. 1Put the phone into download mode by pressing Vol -, Home and POwer key. then Press Vol + key to proceed. Then insert the USB Cable, But the com port not shown in device manager. My qes is "what cable should be used here? Show cable with pictre.... Note: ALL DRIVERS ARE INSTALLED CORRECTLY. Thanks is advance....... |
01-25-2015, 14:02 | #2 (permalink) |
No Life Poster Join Date: Oct 2011 Location: ireland Age: 46
Member: 1670851 Status: Offline Thanks Meter: 267 | if samsung port not shown it means u missing driver if u want to unlock any android phone, u must set usb debugging in phone, when phone is detected drivers should install itself once drivers for phone installed, try to unlock..for some phones select com port of z3x boix, for others new com port will be installed-just choose from com port list on samsung tool main window regards |
01-25-2015, 14:16 | #3 (permalink) |
Member: 2136362 Status: Offline Thanks Meter: 31 | i have previosly told that there is no driver issue, becase there is no yellow mark in the device manager. ok if u tell its drive problm, then give me the driver for the s7562 phone. But I think its cable fault... what cable need to be used? |
01-25-2015, 14:33 | #4 (permalink) |
Member: 1670851 Status: Offline Thanks Meter: 267 | when u pick the model of the phone, u can always use help button in the right top cornerto give u heads up what to do check link below: http://forum.gsmhosting.com/vbb/f453...x-box-1892117/ |
01-25-2015, 14:35 | #5 (permalink) |
Member: 1670851 Status: Offline Thanks Meter: 267 | if u read it whole thread..guy put wrong code before u press unlock Root Phone via vroot Open z3x tool Select Proper model Use UART cable Type *#7284# Choose UART Click unlock so use uart cable for unlock as stated |
01-25-2015, 14:50 | #7 (permalink) | |
Member: 2136362 Status: Offline Thanks Meter: 31 | Quote:
And the debugging is not on, hence how to root? Please clear the following... ----------------------------- Without root, the phone cant be unlock? So normal USB cable wont help me and please show me a picture of z3x uart cable. | |
01-25-2015, 15:35 | #8 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
