10-10-2016, 07:55 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: bangladesh
Member: 1022144 Status: Offline Sonork: Love in Bangladesh Thanks Meter: 139 | can help me g925t imei 35000000000000 ? Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G920F Software version: 26.9 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Searching Samsung modem... detected COM144 Reading phone info... OK Model: SM-G925T AP version: G925TUVU4EPF1 CSC version: G925TTMB4EPF1 CP version: G925TUVU4EPF1 Product code: XXXXXXXXXXXTMB Phone SN: RF1D45EJGGR Unique number: 05157DF5F2DA3F2D Reading IMEI... OK IMEI: 000000000000000 (SIGN: NG_SIGN) Reading data from phone... error (0) Done with Samsung Tool PRO v.26.9 Last edited by Yakub Alli; 10-10-2016 at 08:05. |
10-11-2016, 03:19 | #3 (permalink) | |
Freak Poster Join Date: Oct 2014 Location: puerto rico
Member: 2282504 Status: Offline Thanks Meter: 50 | Quote:
10-11-2016, 03:20 | #4 (permalink) | |
10-11-2016, 03:23 | #5 (permalink) | |
10-12-2016, 07:49 | #7 (permalink) |
Member: 1022144 Status: Offline Sonork: Love in Bangladesh Thanks Meter: 139 | i have taken this condition from castomar . thanks everybody for reply if the backup was expressed from any same new security phone . i think it might be ! what do you say ? |
