12-21-2010, 14:06 | #10 (permalink) |
No Life Poster Join Date: Aug 2009 Location: .:::Sri Lanka:::. posts: 9999 Age: 33
Member: 1093564 Status: Offline Thanks Meter: 326 | Count supported models - 203 Searching Samsung USB interface... not found Searching Samsung USB interface... detected (COM36) Model: SGH-A885 SW: A885TLIK1 IMEI: 357237030****** ----------------------------- Model: SGH-A885 CountryCode: TLS Factory SW: TLIK1 UniqueNumber: 80080000885309 MemoryPhone: K5R2G1GACC(A887)S IMEI: 357237030****** Phone S/N: RV2Z740328 Build: SBAM6290A-KPVZL-1.2.0075_8S Reading SysInfo... OK Calculating... error Searching SysInfo... error |
01-30-2011, 04:55 | #12 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Online Sonork: 100.1597405 Thanks Meter: 1,779 | Quote:
yes is tru bro...waiting mode for z3x team make it | |
04-20-2018, 16:36 | #13 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | Type *#782872# Code: UNLOCK INSTRUCTIONS: Read codes only USB cable : 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Enter *#7465625# (phone must display locks status). 6. Press 'Read codes' to read security codes. Operation: Read Codes Selected model: SGH-A885 Selected port: COM8 USB Serial Port, Version logiciel: 20.0 Lecture d'information du telephone... OK Modèle: SGH-A885 Code pays: ij³ª´Ù Cal date : 2009-11-28 SW D'usine: TLIK1 numéro unique: 80110000336532 mémoire telephone: K5R2G1GACC(A887)S Phone S/N: RVRZ505086 lecture de l'IMEI... OK IMEI: 357237030351610 Lecture Version logiciel... OK Version du telephone: A885TLIK1 Recherche sysinfo en cours...... OK Lecture sysinfo... OK S'il vous plaît attendre, le calcul des codes... OK (Temps - 00:00:35) Freeze code: 60935030 NET lock: 72514846 Sub lock: 00000000 SP lock: 79257526 CP lock: 00000000 Multi lock: 12369874 Verrouillage SIM: 12369874 For check lock status: *#7465625# Réussie avec Samsung Tool v.20.0 |
[19-02-10] Unlock Motorola Milestone from Telus Canada | UnlockBase.com | UnlockBase | 1 | 05-20-2010 01:04 |
Cannot unlock nokia 1110 from Telcel Mexico | jimmydueck | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 02-09-2007 16:20 |
cannot unlock the RSA from my K750i with RED CID-36 | sim1 | Cruiser Suite | 4 | 07-02-2005 10:55 |
