05-15-2015, 14:46 | #1 (permalink) |
Junior Member Join Date: Apr 2008
Member: 762446 Status: Offline Thanks Meter: 13 | canot repair imei sam g313hz http://postimg.org/image/9m2u1ii65/ http://postimg.org/image/sr4e4650n/ |
05-15-2015, 22:09 | #2 (permalink) | |
No Life Poster Join Date: Nov 2013 Location: Third World ;)
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | Quote: Try and post result, and details of how you connected it. BR | |
05-16-2015, 01:32 | #3 (permalink) |
Member: 762446 Status: Offline Thanks Meter: 13 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. connect the phone to PC with USB cable, install drivers if needed. 4. Fill values what you need to repair. 5. Press 'Repair' button. Operation: Repair Selected model: SM-G313HZ Software version: 20.5 Waiting phone... not found Done with Samsung Tool v.20.5 I've been at the root phone |
06-01-2015, 12:48 | #4 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Manila Age: 37
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 92 | same problem right here ========== Operation: Repair Selected model: SM-G313HZ Software version: 20.5 Waiting phone... not found Done with Samsung Tool v.20.5 |
06-01-2015, 13:31 | #6 (permalink) |
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 92 | Selected model: SM-G313HZ Selected port: Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: SM-G313HZ Android version: 4.4.2 Product code: Unknown Phone version: Unknown PDA version: G313HZDBU0ANL1 CSC version: G313HZOLB0ANL1 IMEI: Unknown Phone S/N: Unknown Checking Super user right... true Repairing SN... OK Bypass MSL... error (3) Done with Samsung Tool v.19.1 ========== Read info ========== Selected model: SM-G313HZ Selected port: COM45 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM137 Reading phone info... Software version: =1,1 IMEI: 000000000000000 Done with Samsung Tool v.19.1 Last edited by gwlime; 06-01-2015 at 13:38. |
08-04-2015, 15:23 | #7 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Indonesia
Member: 713923 Status: Offline Thanks Meter: 38 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Repair Selected model: SM-G313HZ Software version: 21.8 Waiting ADB device... OK Reading phone info... Model: SM-G313HZ Android version: 4.4.2 Product code: Phone version: PDA version: G313HZDBU0ANK3 CSC version: G313HZOLB0ANK2 CSC country code: INDONESIA CSC sales code: XSE HW version: Phone S/N: Modem board: RF cal date: IMEI: Checking Super user right... true Bypass MSL... error (-1) Done with Samsung Tool PRO v.21.8 Please Help cant repair imei |
