06-27-2013, 13:57 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: hong kong
Member: 288543 Status: Offline Thanks Meter: 5 | canot unlocke p5100 and i947 why Selected model: P5100 Selected port: COM17 RIM Virtual Serial Port v2 Selected port speed: 115200 Reading phone info... Model: GT-P5100 Android version: 4.0.3 Product code: GT-P5100TSAATL Phone version: P5100BULD5 PDA version: P5100BUALD5 CSC version: P5100VFGALD5 IMEI: Unknown Checking Super user right... false Rooting phone, please wait... error Not supported android version 4.0.3 Done with Samsung Tool v.14.1 Done with Samsung Tool v.14.1 |
06-27-2013, 14:50 | #2 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | i think from log you can easy understand. need root phone manualy. |
The Following User Says Thank You to blang For This Useful Post: |
06-27-2013, 14:51 | #3 (permalink) |
Member: 288543 Status: Offline Thanks Meter: 5 | 2nd June 2012, 12:02 AM (Last edited by cheatman; 7th June 2012 at 03:28 PM.) Reason: added link #1 cheatman's Avatar Senior Member - OP Thanks Meter 1350 Posts: 454 Join Date: May 2007 Location: Migration Institute More Info > DONATE TO ME Thumbs up [ROM][ICS][STOCK][GT-P5100] ICS 4.0.3 Stock Safe / Recovery / Root (P5100XWALD7) ================================================== ======================================= === Device: GT-P5100 (Galaxy Tab 2, 10.1", 3G model) === Description: Safe stock ODIN image, recovery and root === Packaged by: cheatman ( xda - xda-developers - View Profile: cheatman ) === Stock ROM version: P5100XWALD7 === Build date: 07 June 2012 ================================================== ======================================= Disclaimer: I am not responsible and assume no liability on how this information is used. This package is provided "as is" without any warranty and does not guarantee any fitness for any purpose. ONLY FOR GT-P5100 (3G model)!!! Do not flash on any other Galaxy Tab 2!!! Download the ZIP (large, about 600MB) from here: => DOWNLOAD FROM HERE (HotFile) How to use: Read the readme.txt file or this post here. On to the safe stock restore process: 1. Make sure you have the Samsung device drivers installed before you begin. If you don't, install them from here: - 64bit: http://drivers.softpedia.com/get/MOB...dows-x64.shtml - 32bit: http://drivers.softpedia.com/get/MOB...dows-x86.shtml 2. Make sure your tablet's battery is at least 30% charged up before you begin. 3. Make sure you have an external microSD inserted in the device, if you also plan on rooting afterwards. Nothing will be erased from the microSD, there is no need to worry about that. 4. Run procedure to flash back the stock ROM from Samsung (Ice Cream Sandwitch 4.0.3 - P5100XWALD7) from the folder "Step1-Stock". STOP HERE FOR PURE STOCK!!! 5. Run procedure to enable ClockworkMod recovery from the folder "Step2-Recovery". This step is OPTIONAL (only if you want a custom recovery). STOP HERE IF YOU DON'T WANT ROOT!!! 6. Run procedure to enable "root" access from the folder "Step3-Root". 7. Done! Enjoy! Profit! ================================================== ============= ========== Step 1 - Flashing Stock P5100XWALD7 ================ ================================================== ============= 1. Download the file from the link above. 2. Shut down your tab. 3. Disconnect tab from USB and/or power cables. 4. Hold "Power+Volume UP" physical buttons on your tablet to initiate download mode. 5. Press "Volume DOWN" physical button on your tablet to confirm and enter ODIN mode. 6. On your PC, open "Odin3 v1.85.exe" 7. Press "PDA" button in ODIN and select the "PLATFORM_P5100XWALD7_482645_REV02_user_low_sh ip.t ar.md5" file. 8. Press "PHONE" button and select the "MODEM_P5100XXLD7_REV_01_CL1128355.tar.md5" file. 9. Connect your tablet using a USB cable. In ODIN you should see the device "<added>" message appear. If you do not, there is a problem with the Samsung drivers installation. 10. Confirm that only the following options are checked in ODIN: "Auto Reboot", "F. Reset Time", "PDA", "PHONE". DO NOT CHECK RE-PARTITION!!! NEVER!!! 11. Click the big "Start" button and WAIT. Be patient!!! The process takes about 3-4 minutes but can take longer. 12. Do not power down the tablet while this takes place. Do not shut down your PC. Do not touch anything! Just wait! Get a coffee or something... 13. After full flash the tablet will reset automatically. 14. Congratulations you are now safely back to stock P5100XXALD6. 15. There is no need to flash the bootloader and CSC. Do so at your own risk. ================================================== ================= ========== Step 2 - Flashing ClockworkMod Recovery ================ ================================================== ================= 1. Download the attached recovery file "p5100-recovery.tar.md5.zip" and extract it. 2. Shut down your tab. 3. Disconnect tab from USB and/or power cables. 4. Hold "Power+Volume UP" physical buttons on your tablet to initiate download mode. 5. Press "Volume DOWN" physical button on your tablet to confirm and enter ODIN mode. 6. On your PC, open "Odin3 v1.85.exe" 7. Press "PDA" button in ODIN and select the "p5100-recovery.tar.md5" file. 8. Connect your tablet using a USB cable. In ODIN you should see the device "<added>" message appear. If you do not, there is a problem with the Samsung drivers installation. 9. Confirm that only the following options are checked in ODIN: "Auto Reboot", "F. Reset Time", "PDA". DO NOT CHECK RE-PARTITION!!! NEVER!!! 10. Click the big "Start" button and wait a few seconds. Flashing recovery.img is super-fast! 11. After recovery flash, the tablet will reset automatically. 12. Congratulations you are now running recovery for your tablet. 13. Note: Internal SD is not working with this recovery, you must use external microSD cards to load up ZIPs. 14. You can also download and extract the kernel and flash it also on "PDA" if you want a rooted Kernel ================================================== ======= ========== Step 3 - Enabling root access ================ ================================================== ======= 1. Download the attached file "CWM-root-P5100-v1.zip". 2. Copy the "CWM-root-P5100-v1.zip" file to the external microSD card. 3. Shut down your tab. 4. Insert the microSD in the tablet. 5. Hold "Power+Volume DOWN" physical buttons on your tablet to initiate recovery mode. It takes a while to start up recovery (10-15 seconds) so be patient. Try not to press too hard on the buttons as it does not help at all (takes same amount of time ) 6. Use the "Volume UP" and "Volume DOWN" buttons to navigate (select options) and the "Power" button to select. Don't HOLD the buttons, just press them (like a click or something). 7. Select the option to install ZIP from sdcard. 8. Navigate to where you copied the "CWM-root-P5100-v1.zip" file and select it. 9. Wait for the operation to complete. 10. Navigate back and select option to "Reboot system" 11. Congratulations you have a fresh stock ROM with CWM and root ready to go! 12. Enjoy ================================================== ===================================== Thanks and greetings go to: - Galaxian-Soup - nycbjr - All others who help and bring value to the XDA comunity! |
06-27-2013, 14:53 | #4 (permalink) |
Member: 288543 Status: Offline Thanks Meter: 5 | thanks for repley but you dont tell how to manunaly root right this is the soualtion for root not for unlocking ok but still thanksssssssssss to reply mr blang |
06-27-2013, 14:55 | #5 (permalink) |
Member: 288543 Status: Offline Thanks Meter: 5 | Selected model: P5100 Selected port: COM27 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM58 Reading phone info... Model: GT-P5100 Country code: ATL Cal date: - Factory SW: P5100BUALD5 Unique number: CMA0741054AED7F Memory phone: - Software version: P5100BUALD5/P5100VFGALD5/P5100BULD5/P5100BUALD5 IMEI: 352816055415866 Product code: GT-P5100TSAATL Done with Samsung Tool v.14.3 Selected model: P5100 Selected port: COM27 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-P5100 Android version: 4.0.3 Product code: GT-P5100TSAATL Phone version: P5100BULD5 PDA version: P5100BUALD5 CSC version: P5100VFGALD5 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.14.3 Done with Samsung Tool v.14.3and know susses for unlocke thanks zxe teem and xda devlopers thanksssssssssssssssssss i done unlocke |
06-27-2013, 15:07 | #6 (permalink) |
Member: 288543 Status: Offline Thanks Meter: 5 | Selected model: P5100 Selected port: COM27 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM50 Reading phone info... Software version: I497UCALJ3/I497UCLJ3/I497ATTALJ3 IMEI: 353488050286665 Product code: SGH-I497ZSAATT Done with Samsung Tool v.14.3 Selected model: P5100 Selected port: COM27 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SAMSUNG-SGH-I497 Android version: 4.0.4 Product code: SGH-I497ZSAATT Phone version: I497UCLJ3 PDA version: I497UCALJ3 CSC version: I497ATTALJ3 IMEI: Unknown Checking Super user right... true Reading data from phone... error Done with Samsung Tool v.14.3 Done with Samsung Tool v.14.3but still canot unlocke i479 can you help me plaseeeeeeeeeeeeee |
