03-10-2014, 16:03 | #1 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48396 Status: Offline Thanks Meter: 82 | Can't fix no network N7100 If I power on phone without sim card, then it looks that it have network, but when I trying to make an emergency call, then it lose signal ang get it back after about 20 seconds. If I power on phone with sim card inside, then it is no network. So, is there any way to fix this problem with z3x box atm? BR |
03-19-2014, 04:43 | #3 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | Hi.. could you please tell us the rom you used for downgrade?? I have this one note2 imei null.. thanks sent from my sm-n900 using tapatalk |
03-19-2014, 12:11 | #4 (permalink) |
Member: 48396 Status: Offline Thanks Meter: 82 | U can fix imei on any version, 4.3, 4.1.2 or 4.1.1. I downgraded to N7100XXDME6 (4.1.2) trying to fix s/n. I fixed s/n with 16.7 as I thought, but only 10 digits was restored, not 11 as it should. So my phone still have no network. BR |
03-19-2014, 16:21 | #8 (permalink) |
Member: 48396 Status: Offline Thanks Meter: 82 | Unpack firmware? U will get build_name.tar.md5 file. Remove .md5 at the end of file, U will get build_name.tar file. After that U have 2 methods how to edit that fw file. 1. Use Total Commander. Start TC, navigate to your file, double click it to open. Delete param.bin sboot.bin tz.img files. It can be only 2 files in fw, without param.bin, then delete only 2 this files. Close file by clicking [..]. Now this file can be flashed via Odin, selected as PDA. or 2. Unpack build_name.tar using latest Winrar or 7-Zip in any folder, delete files I've pointed above. Pack files back to tar archive using 7-Zip. Flash via Odin, selecting as PDA. After editing firmware U should get something like this: P.S. I'm using method No.1, b'cos it's simple and TC is my favorite file manager and I'm using it since it was released in public (about 20 years ago). |
The Following User Says Thank You to UnReality For This Useful Post: |
03-20-2014, 05:29 | #9 (permalink) |
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | Well ive downgraded using spt option to 4.1.1 now i can flash any rom i want.. but the imei stills null.. always "checking magic: not found" and if use okd versions.. cant find phone through uart cable.. if i dial *#9090# there is no options.. its empty.. how can i fix this problem?? sent from my sm-n900 using tapatalk |
