Cant reset security codes lg ks360 HERE ARE MY FAILED ATTEMPTS LOGS Loading module , please wait... PMB8888 Module 2.1 started. SW: Ver 3.5.0.0 Connecting to LG KS360 in UART Mode (COM8 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8888) prebooting... Release power button. Booting... Reading info... Flash ID: 0000 BOOT Stage Finished , sending authority... Sending SEC pack... Reading EEPROM... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG KS360_autobackup_18062011_152035.eep Detailed Phone Information: Phone Model: Phone Manufacturer: LG Elec. Inc Phone Version: Undefined Phone IMEI : 35924003263284500 Phone BT Adress : 8C:54:1D:09:0E:B6 Detailed Codes Information: Phone NCK Code : 0022-2056 Phone NS Code : 5539-2845 Phone SP Code : 6843-8155 Phone CP Code : 1181-8732 Phone SIM Code : 7902-5709 SimLocks Disabled SP Lock Disabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config: Finished in 3 seconds Reading codes... Sending SEC pack... Reading ... Detailed Phone Information: Phone Model: Phone Manufacturer: LG Elec. Inc Phone Version: Undefined Phone IMEI : 35924003263284500 Phone BT Adress : 8C:54:1D:09:0E:B6 Detailed Codes Information: Phone NCK Code : 0022-2056 Phone NS Code : 5539-2845 Phone SP Code : 6843-8155 Phone CP Code : 1181-8732 Phone SIM Code : 7902-5709 SimLocks Disabled SP Lock Disabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config: For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*71001# to enter unlock menu 3. Enter one of this code(s): Finished in 3 seconds Unlocking... Sending SEC pack... Reading EEPROM.... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG KS360_autobackup_18062011_152107.eep SimLocks Disabled SP Lock Disabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config: SimLock Data Fixed! Writing EEPROM.... Sending SEC pack... Writing Backup EEPROM.... Sending SEC pack... Unlock done! Finished in 11 seconds |
2945#*71001# use this wit out simand fectroy rest |
my friend this does not work on this type of phone |
phone must be on and click factory reset(usercode) on software |
tried all user codes did not work for this phone it is true you can see all the user codes not only that when you perform unlock the software shows all codes disabled but still no lucky |
there is not usercode disabel u must phone on use ke500 cable and click fectroy seting. |
Please clarify wahat you want to do ? User code can be resetted only what phone powered on and connected to KE500 cable. Click factory reset and user lock will be resetted. |
Hard reset lg ks 360 done ok HARD RESET LG KS 360 DONE OK HARD RESET LG KS360 DONE OK IN POLAR BOX WITH CABLE LG KE500 VYGIS OR CABLE KE 500 POLAR CLICK SET FACTORY AND CONNECT PHONE PHONE MUST BE ON ......... Engine Compilation Build : 343 Reseting Phone...Wait... First Response Received... Phone is Settings Default.... DONE NO CODE OF SECURITY http://forum.gsmhosting.com/vbb/f177...ne-ok-1790698/ |
