05-09-2015, 11:10 | #1 (permalink) |
Junior Member Join Date: May 2015
Member: 2391034 Status: Offline Thanks Meter: 1 | Can't unlock S5222 with Samsung Pro v.21.0 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 003000EC Reading security... error Done with Samsung Tool PRO v.21.0 I'm using Sam S8300 cable from GPG. Please help |
05-09-2015, 21:17 | #2 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Brother After Flash You Need To Power On Phone Insert Data Cable Install Driver Then Click On Unlock For Sim Lock Uart Cable Use For Phone Lock |
05-09-2015, 23:58 | #3 (permalink) |
Member: 2391034 Status: Offline Thanks Meter: 1 | It's not working. The phone is not recognized if I use the UART cable. It works only with USB (after pressing down volume), but it's not unlocking. Same log: Operation: Unlock Selected model: GT-S5222 Selected port: Auto, 921600 Software version: 21.0 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 003000EC Reading security... error Done with Samsung Tool PRO v.21.0 |
05-10-2015, 00:47 | #5 (permalink) |
Member: 2391034 Status: Offline Thanks Meter: 1 | I connected in normal mode. Same thing. I even tried with Samsung v.19 and It can't seem to find modem. I also have that very annoying popup with "card removed" almost every time I insert usb cable into z3x box. Any Ideas? |
05-10-2015, 01:02 | #6 (permalink) |
Member: 2391034 Status: Offline Thanks Meter: 1 | It looked like it worked, But when I tried with orange SIM it didn't Selected model: S5222 Selected port: COM4 Intel(R) Active Management Technology - SOL Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 003000EC Reading security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM5 Reading phone info... Model: GT-S5229 Country code: VOP Factory SW: S5229BULC3_VFGLC3 Unique number: 79670000945612 Memory phone: K5W1G12ACP(S5222)S Software version: S5222VJLH1/S5222ZTOLH1 IMEI: 35189005064354 Bypass MSL... OK Unlocking... OK Done with Samsung Tool v.19.1 |
05-10-2015, 09:42 | #9 (permalink) |
No Life Poster Join Date: May 2012 Location: BHARAT
Member: 1766148 Status: Offline Sonork: 100.1614494 Thanks Meter: 490 | Check this whole thread [http://forum.gsmhosting.com/vbb/f453...e-z3x-1452481/], You will get your solution. |
05-10-2015, 15:44 | #11 (permalink) |
Member: 2391034 Status: Offline Thanks Meter: 1 | I believe my z3x box is broken, because 9 of 10 times when I connect the cable after I click read info (on all versions v.21,v.19 and 2G samsung tool) I get "Card removed". Here are some logs: 2G Samsung tool: Selected model: S5222 Selected com port: COM4 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... Card removed! Timeout Read info - fail Elapsed time: 92 second, sw ver: 3.5.0040 http ://postimg. org/image/66whi9e27/ |
