05-13-2013, 21:02 | #16 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Serbia
Member: 82990 Status: Offline Thanks Meter: 106 | Quote:
ROOT_S6810PXXAMB1_S6810PMTLAMB1_S6810PXXAMAA_HOME. zip ROOT_S6810PXWAMC1_S6810POLBAMC2_S6810PXWAMC1_HOME. zip all files stops on 99% system.img 2. for ROOT_S6810PXXAMC3_DTMAMC1.zip use boot, pda, modem, csc for ROOT_S6810PXXAMB1_S6810PMTLAMB1_S6810PXXAMAA_HOME. zip and ROOT_S6810PXWAMC1_S6810POLBAMC2_S6810PXWAMC1_HOME. zip only pda 3. yes I use z3x soft for flash | |
05-13-2013, 21:25 | #18 (permalink) | |
Junior Member Join Date: Nov 2005 Location: NETHERLANDS / POLAND
Member: 201395 Status: Offline Thanks Meter: 4 | Quote:
root is work read codes not work?? where is code for unlock ?? screenSHU - The fastest screen capture ever. | |
05-13-2013, 21:29 | #19 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | Quote:
You can use direct unlock But one man post phone dead after press unlock. So we want find problem, may be problem in root. | |
05-13-2013, 21:32 | #20 (permalink) | |
05-13-2013, 21:45 | #23 (permalink) | |
I think after playing with different files flashing something happends. ANyway wait for new files. we will prepair now and you can test | |
05-14-2013, 21:42 | #30 (permalink) |
Member: 82990 Status: Offline Thanks Meter: 106 | same problem system.img stop on 99% file used: ROOT_S6810PXXAMC3_DTMAMC1.zip fleshing log with z3x soft v14.4 Selected model: S6810P Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x3845C1BA Searching USB Flash Interface... detected COM54 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Saved to D:\Program Files\Z3X\Samsung\SamsungTool\Pit\S6810P_14-5-2013_22-26-49.pit Sending BcmBoot.img... OK Sending sboot.bin... OK Sending param.lfs... OK Sending dt-blob... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... Error Done with Samsung Tool v.14.4 flashing log without pda selected Selected model: S6810P Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x0A91013C Searching USB Flash Interface... detected COM54 Setup connection... OK Reading PIT from phone... OK Saved to D:\Program Files\Z3X\Samsung\SamsungTool\Pit\S6810P_14-5-2013_22-33-50.pit Sending BcmBoot.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:00:37) Done with Samsung Tool v.14.4 phone now can power ON read codes log after phone power ON Selected model: S6810P Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S6810P Android version: 4.1.2 Product code: Unknown Phone version: S6810PXXAMC3 PDA version: S6810PXXAMC3 CSC version: S6810PDTMAMC1 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:24) For check lock status: *#7465625# Done with Samsung Tool v.14.4 read codes not working... |
