01-03-2017, 15:16 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Manchester, UK
Member: 180873 Status: Offline Thanks Meter: 80 | Cant unlock Samsung J510FN Code: UNLOCK INSTRUCTIONS: This phoe can be unlocked with unique original MSL code only! 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Done with Samsung Tool PRO v.27.7 Operation: Unlock Selected model: SM-J510FN Selected port: COM3 USB Serial Port Software version: 27.7 Checking phone at COM3 Ok Reading phone info... Ok Model: SM-J510FN Country code: O2U Factory SW: J510FNXXU1APG9 Unique number: CQ300DBB86AB573 IMEI: 35262108626569 Reading SN... Ok Phone SN: RF8H91DHXJ Incorrect size of MSL Done with Samsung Tool PRO v.27.7 |
01-04-2017, 12:07 | #3 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 677934 Status: Offline Thanks Meter: 28 | me tooo cant read phone UNLOCK INSTRUCTIONS: This phoe can be unlocked with unique original MSL code only! 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J510FN Selected port: COM81 SAMSUNG Mobile USB Serial Port Software version: 27.7 Checking phone at COM81 no answer from phone Done with Samsung Tool PRO v.27.7 |
01-04-2017, 12:24 | #4 (permalink) |
Junior Member Join Date: Dec 2007
Member: 666208 Status: Offline Thanks Meter: 2 | i think j510 not yet support direct unlock u must have MSL code to unlock that phone UNLOCK VIA MSL CODE(IF YOU HAVE IT OR GOT IT FROM INSIDER!!. WITHOUT MSL CODE YOU CAN'T UNLOCK!!!! SOLUTION WORK ONLY VIA UART CABLE!!! - support SM-J5108 (unlock via msl code(if you have msl code)) - support SM-J510F (unlock via msl code(if you have msl code)) - support SM-J510FN (unlock via msl code(if you have msl code)) - support SM-J510GN (unlock via msl code(if you have msl code)) - support SM-J510H (unlock via msl code(if you have msl code)) - support SM-J510K (unlock via msl code(if you have msl code)) - support SM-J510L (unlock via msl code(if you have msl code)) - support SM-J510MN (unlock via msl code(if you have msl code)) - support SM-J510S (unlock via msl code(if you have msl code)) - support SM-J510UN (unlock via msl code(if you have msl code)) DO NOT ASK WHERE GET MSL - WE NOT HAVE AND WILL NOT HAVE !!! goto market place or codes sections and ask there |
01-06-2017, 08:08 | #7 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2041992 Status: Offline Thanks Meter: 2 | I did not understant - why there is J510 support for unlock, but you need MSL code, that no one knows where to get |
The Following User Says Thank You to agol123 For This Useful Post: |
02-06-2017, 17:21 | #8 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 42
Member: 106391 Status: Offline Thanks Meter: 37 | Quote:
i try and working if you have octopus/octoplus box and need 220 credits | |
04-01-2017, 12:43 | #11 (permalink) | |
No Life Poster Join Date: Mar 2008 Age: 39
Member: 738945 Status: Offline Thanks Meter: 58 | Quote:
