06-06-2012, 11:40 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: sibiu
Member: 167213 Status: Offline Thanks Meter: 21 | can't unlock samsung s7500 Phone S/N: RV1C34M2N1 Build: 76XXU-USNSKRLYM-109806 IMEI: 3588660431 PDA/CSC Version: S7500BULB1/S7500CNXLB2 Phone version: S7500BULB1 Phone HW: MP 0.700 Cal Date: 2012.03.31 Read Security... OK Bypass MSL... OK Reading Codes... OK MCK: ô†i cäº NCK: <åÏèoñ*b NSCK: ýrçbПšÊ SPCK: ýrçbПšÊ CPCK: ýrçbПšÊ |
06-25-2012, 18:31 | #2 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Ireland
Member: 255466 Status: Offline Thanks Meter: 12 | Follow the procedure for root, next unlock by z3xbox. xda-developers - View Single Post - [Q] Samsung Galaxy ACE plus GT-S7500 |
07-12-2012, 07:53 | #3 (permalink) |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | Please follow these instructions carefully: Download and unzip Odin3. Download the ROOT.tar file which contains the modified boot.img. Put the phone into download mode(volume down+home+power on) Flash the ROOT.tar file as PDA & wait for the phone to reboot. Now root using DooMLoRD's Easy Rooting Toolkit run "runme.bat" *#7284# - select usb restart use z3x samsung tool v12.6 or newer select s7500 check unlock; check read full nvm press unlock Enjoy full access to your rooted phone log : Reading Phone Info... OK Model: GT-S7500 Country Code: CNX Cal Date: ªU Factory SW: S7500BULB1 Unique Number: CSJ08E0E63BDA3F Memory Phone: ªU Phone S/N: RV1C51HR63 Build: 76XXU-USNSKRLYM-109806 IMEI: 358866045937200 PDA/CSC Version: S7500BULB1/none Phone version: S7500BULB1 Phone HW: MP 0.700 Cal Date: 2012.05.15 Read Security... OK Bypass MSL... OK Unlocking ... OK Done with Samsung Tool ver 12.6 PRESS THANKS !!! |
The Following User Says Thank You to zullu2004 For This Useful Post: |
07-12-2012, 08:07 | #4 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | Why the **** do you want to root this phone when you don't need to? It is verry verry simple to unlock it. Z3X does NOT support READ CODES on this model. So it supports ONLY DIRECT Unlock and this procedure dosen't need ROOT. Just enable USB Debugging connect C3300K cable, select Unlock and the push UNLOCK button. Peace of cake! Pe romaneste nu iti trebuie nici un root. Doar unlock cu cablul C3300k ca nu stie sa citeasca codurile. In 3 minute ai decodat telefonul fara nici un efort. Poti sa apesi tu acum butonul de Thanks |
The Following User Says Thank You to ZiDanRO For This Useful Post: |
