02-20-2016, 19:51 | #5 (permalink) |
Freak Poster Join Date: Nov 2006 Location: NJ, USA
Member: 399404 Status: Offline Thanks Meter: 70 | keep getting the same error .. I was 5.0.1 same thing, updated to 5.1.1 rooted same thing tried it with 19.1 more than 3 times and same .. BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N910T Selected port: COM27 SAMSUNG Mobile USB Serial Port Software version: 24.3 Checking certificate file... OK KEY ID: 0772 Waiting ADB device... OK Reading phone info... Model: SM-N910T Android version: 5.1.1 Product code: SM-N910TXXXTMB Phone version: N910TUVU2DOK2 PDA version: N910TUVU2DOK2 CSC version: N910TTMB2DOK2 CSC country code: USA CSC sales code: TMB HW version: REV1.1 Phone S/N: Modem board: MDM9225M RF cal date: 2014.10.16 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool Pro |
02-20-2016, 23:55 | #6 (permalink) | |
Freak Poster Join Date: Apr 2010
Member: 1288575 Status: Offline Thanks Meter: 36 | Quote:
The Following User Says Thank You to clippy165 For This Useful Post: |
