06-16-2017, 09:56 | #4925 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | READ QCN G900FQ DONE BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Read QCN Selected model: SM-G900FQ Selected port: COM191 SAMSUNG Mobile USB Serial Port Software version: 28.2 Reading ID... OK Detected ID: 00000FF3 (MSM8974) SW version: MPSS.DI.2.0.1.c2.7-00047-M8974AAAAANRZM-1 Reading ESN... OK Backuping RFNV... Ok Backuping FeatureMask... Ok Backuping NV Item... Ok Backuping NV Item SIM1... Ok Backuping NV Item SIM2... Ok Backuping Provisioning Item Files... Ok Reading QCN done Done with Samsung Tool PRO v.28.2 LINK:https://forum.gsmhosting.com/vbb/****************************/?l3ivpjr77e0n70r |
06-26-2017, 14:59 | #4928 (permalink) |
Junior Member Join Date: Jan 2014 Location: Venezuela
Member: 2110831 Status: Offline Thanks Meter: 2 | I need or exchange cert Hello, I need cert sm-G900h or exchange from venezuela. I'm trying to post the ones I have that are still good, but I'm not allowed to do so if they are so friendly, thanks |
06-26-2017, 16:54 | #4929 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2273543 Status: Offline Thanks Meter: 1 | Exchange i have certs for: a500M a500F j500m G531m j100mu N900 G710 and others For Exchange!!! contact me |
The Following User Says Thank You to gonzoolivares For This Useful Post: |
06-28-2017, 04:58 | #4931 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2179862 Status: Offline Thanks Meter: 17 | Quote:
I'm the owner of a Verizon S7 edge which has missing IMEI. When it's on download mode, there's an option where it shows the IMEI number (the option is show codebar), but I don't know why it's missing from the phone information on settings and obviously has no signal. Can you please provide some information about how to make it work again? I'm a noob, but I learn quickly. Any information would be very appreciated. Enviado desde mi FRD-L04 mediante Tapatalk | |
