07-18-2017, 09:20 | #4943 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-E500H Selected port: COM340 SAMSUNG Mobile USB Serial Port Software version: 28.2 Checking CERT file... Ok KEY ID: 0056 Waiting ADB device... Ok Reading phone info... Model: SM-E500H Android version: 4.4.4 Product code: SM-E500HZKDXFE Phone version: E500HXXU1AOD1 PDA version: E500HXXU1AOD1 CSC version: E500HOJV1ANL7 CSC country code: SOUTH AFRICA CSC sales code: XFE HW version: MP 0.800 Phone SN: RV1G707RXRE Modem board: MSM8216 RF cal date: 2015.07.07 IMEI: 358484065745618 Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0056 Writing CERT... Ok Checking CERT status... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.28.2 |
07-18-2017, 09:20 | #4944 (permalink) |
07-18-2017, 10:52 | #4945 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Read CERT' button to read certificates or 'Write CERT' to restore. Operation: Write CERT Selected model: SM-G531F Software version: 28.2 Checking CERT file... Ok KEY ID: 0001 Waiting ADB device... Ok Reading phone info... Model: SM-G531F Android version: 5.1.1 Product code: SM-G531FZDASER Phone version: G531FXXU1APC1 PDA version: G531FXXU1APC2 CSC version: G531FSER1APC1 CSC country code: Russia CSC sales code: SER HW version: MP 0.200 Phone SN: RV8GB1F5HLB Modem board: Security patch: 2016-03-01 RF cal date: 20151120 IMEI: Checking Super user right... true Reading NV data... Ok Analyzing SEC file... Ok Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0001 Writing CERT... Ok Checking CERT status... Ok Rebooting phone... Ok Write CERT done Done with Samsung Tool PRO v.28.2 |
07-18-2017, 10:55 | #4946 (permalink) |
07-21-2017, 09:28 | #4947 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-A510L Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-A510L Android version: 5.1.1 Product code: Phone version: A510LKLU1APB2 PDA version: A510LKLU1APB3 CSC version: A510LLUC1APB3 CSC country code: KOREA CSC sales code: LUC HW version: A510L.02 Phone SN: R39GC0J54G Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2016-02-01 RF cal date: 20151223 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... error (0 4) Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON310 HWID: CD 88 E5 6D 7D DD 9F 63 44 8B 5D 2D B6 95 8F 8F Calculating... Ok Initialization AT RIL... AT RIL stopped, restarting... Ok Checking for compatible phone and cert Phone KEY ID: 0120 Checking certificate file... Ok KEY ID: 0120 Crypting CERT 1... Ok Writing NV data... Ok Rebooting phone... Ok Write CERT done Done with Samsung Tool PRO v.28.2 |
07-21-2017, 09:28 | #4948 (permalink) |
