01-24-2018, 13:10 | #5105 (permalink) |
Insane Poster Join Date: Sep 2013 Location: ke
Member: 2025275 Status: Offline Thanks Meter: 71 | Incoming massive certs upload. This time file uploads won't expire anymore. http://digital-dragons.net/search2/s...&result=Submit Complete with MD5 Checksum to verify that files are correct. |
01-27-2018, 10:35 | #5107 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Write CERT Selected model: SM-A510F Software version: 30.5 Waiting ADB device... OK Reading phone info... Model: SM-A510F Android version: 7.0 Product code: Phone version: A510LKLU1CQF1 PDA version: A510FXXU4CQG7 CSC version: A510FOJV4CQG1 CSC country code: TURKEY CSC sales code: TUR HW version: Phone SN: Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-07-01 RF cal date: IMEI: 354381070108754 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: CD 88 E5 6D 7D DD 9F 63 44 8B 5D 2D B6 95 8F 8F Calculating... OK Initialization AT RIL... AT RIL stopped, restarting... OK Checking for compatible phone and cert Phone KEY ID: 0120 Checking certificate file... OK KEY ID: 0120 Crypting CERT 1... OK Writing NV data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.30.5 |
01-27-2018, 10:35 | #5108 (permalink) |
02-06-2018, 14:03 | #5115 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Not SPAM more with you Useless request. All these model are CPID device based, so you can use for Nothing, cannot Write Any other CERT in these models, only his ORIGINAL CERT....so you request are only SPAM!!! |
