05-16-2018, 20:53 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2691110 Status: Offline Thanks Meter: 1 | Codigo incorreco N920P Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G955U Software version: 31.5.1 Checking Login and Password... Listo Ballance: 60 crd. You have 60 credit(s) left. This operation takes 5 credits.Continue? Si Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-G955U Android version: 7.0 PDA version: G955USQU2BQK5 CSC version: G955UOYN2BQK5 Versión del telefono: G955USQU2BQK5 Código del Producto: SM-G955UZSACCT Código de país CSC: USA Código de Venta CSC: CCT Phone SN: R28J63L85BH IMEI: 355988080390476 HW version: REV1.0 RF cal date: 2017.06.29 Chip name: MSM8998 Módem: MSM8998 Security patch: 2017-11-01 Boot Warranty bit: 0 Waiting for device to become ready... Listo Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Searching Ramdump interface... COM104 detected Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Congelar código: 46814625 NET lock: 57930572 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Para comprobar bloquea el estado: *#7465625# Done with Samsung Tool PRO v.31.5.1 Los dos codigos que arrojo el servidor me lo marca como incorrecto |
05-16-2018, 21:15 | #3 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | Quote:
