10-11-2013, 22:05 | #2 (permalink) |
Crazy Poster Join Date: May 2012
Member: 1763087 Status: Offline Sonork: 100.1647199 Thanks Meter: 4 | i too, i need EFS from qualcomm chips, e.g S7562L, S7560M, I9505, if new pcb main, write imei ok, but dont remove factory mode screen (yellow screen) need EFS for remove this screen =/ |
10-12-2013, 04:49 | #3 (permalink) |
Member: 1763087 Status: Offline Sonork: 100.1647199 Thanks Meter: 4 | Here is the exact solution for this problem which i have recently had! You have to root your phone and install Terminal Emulator from Google Play. Open terminal emulator and type as ; su rm /efs/FactoryApp/keystr rm /efs/FactoryApp/factorymode echo -n ON >> /efs/FactoryApp/keystr echo -n ON >> /efs/FactoryApp/factorymode chown 1000.1000 /efs/FactoryApp/keystr chown 1000.1000 /efs/FactoryApp/factorymode chmod 0744 /efs/FactoryApp/keystr chmod 0744 /efs/FactoryApp/factorymode reboot Worked for me. Also brought back my lock screen and my power button options, i do think a rom messed about with my efs file. other box, this function is called safe mode removes |
The Following User Says Thank You to f3l1p1nh0 For This Useful Post: |
02-19-2017, 06:45 | #4 (permalink) | |
No Life Poster Join Date: Oct 2008 Age: 39
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | Quote:
in z3x just select i 9300 and click disable factory mode done... | |
