09-24-2015, 09:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Help me To Unlock SHV-E300K Please help me out Team or any User: LOGS: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SHV-E300K Software version: 20.5 Waiting ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: SHV-E300K Android version: 5.0.1 Product code: Phone version: E300KKTUBOB3 PDA version: E300KKTUGOC7 CSC version: E300KKTTGOC7 CSC country code: KOREA CSC sales code: KTT HW version: E30.14 Phone S/N: R33D705E5D Modem board: SS222 RF cal date: 20130708 IMEI: Checking Super user right... true Reading nv data... OK Checking magic... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.20.5 |
The Following User Says Thank You to BISMILLAH MOBILES For This Useful Post: |
09-26-2015, 11:01 | #5 (permalink) | |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Thanks Sir for replying... Quote:
Waiting for reply... Sheraz.. | |
10-25-2017, 03:08 | #6 (permalink) |
Crazy Poster Join Date: Nov 2016 Location: The Greatest fiji islands
Member: 2644395 Status: Offline Thanks Meter: 11 | blang plz reply asap the imei was ok before i unlocked but when i unlocked the imei gone bad 00000000 like that now limited service only i try to repair imei but security damaged i dont have any backup for nvdata and cant find any over the net as well asap reply needed |
10-26-2017, 11:54 | #7 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,550 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
10-26-2017, 12:01 | #8 (permalink) |
Member: 2644395 Status: Offline Thanks Meter: 11 | blang sorry it was about SHV-E300K i need help on this model already unlocked it with z3x then wat happened it got imei 000000000000/1 i dont have any back ups please help |
10-26-2017, 12:09 | #9 (permalink) | |
10-26-2017, 12:31 | #10 (permalink) |
Member: 2644395 Status: Offline Thanks Meter: 11 | model SHV-E300K JOB imei repair after unlock error.security damaged full log here REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Repair Selected model: SHV-E300K Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SHV-E300K Android version: 4.4.2 Product code: Phone version: E300KKKUANI1 PDA version: E300KKKUFNL3 CSC version: E300KKTTFNL3 CSC country code: KOREA CSC sales code: KTT HW version: Phone SN: 00000000000 Modem board: SS222 RF cal date: IMEI: 000000000000000 Checking Super user right... true Reading NV data... OK Security damaged Done with Samsung Tool PRO v.29.5 note.i have no backups and cant find over the internet as well any solution will be appreciated.thanks alot |
