06-23-2015, 18:53 | #1 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1783280 Status: Offline Thanks Meter: 1 | Diag Activation done!!! but no diag port... |
06-23-2015, 20:29 | #2 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Man android v5.x need diag activation all older android got it activated from begining. Just read instruction from z3x after select model do all step and you will got comunication with phone iwthout problem. Just fallow instruction !! !! !! |
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
06-23-2015, 22:00 | #4 (permalink) |
Member: 1783280 Status: Offline Thanks Meter: 1 | I fallow the instructions but when you dial *#9090# it says "Diag Config Not Supported" and of course I can't unlock the phone. There is no way that I can put this phone in diag mode. |
06-23-2015, 23:42 | #5 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Man be a real and read little forum new code is *#0808# from long time and after select DM+MODEM+ADB. |
The Following 2 Users Say Thank You to wgmmmx1 For This Useful Post: |
06-26-2015, 00:30 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Diag Activation done!!! but no diag port... Then you can try with GPG UART cable. It can set different Register value. U can use number 2 value and plug into phone and restart mobile, with plug in UART cable u can access *#7280# & *#0808# after change option u can connect mobile with pc n install drive the try to unlock. I did this policy many times. Good Luck. Sent from my iPhone using Tapatalk |
