08-04-2012, 09:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: poland Age: 44
Member: 46621 Status: Offline Thanks Meter: 34 | e1200 flash and unlock by z3x box :) just select e1200m Selected model: E1200M Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F815 Sending loader2... OK Start NOR flash NOR flash - ok Download - ok Elapsed time: 162 second, sw ver: 3.5.0038 br |
08-04-2012, 10:00 | #2 (permalink) |
Member: 46621 Status: Offline Thanks Meter: 34 | unlock Selected model: E1200M Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F8C5 Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 3518610517xxxx Phone slave IMEI: 3518610517xxxx Phone SW: E1200XPLD1 Phone CSC: E1200OXALCB Phone BT ADDR: 0000-00-000000 Phone SN: RV1C635Z77 Deactivated MSL - TRUE Unlock - FAIL Elapsed time: 54 second, sw ver: 3.5.0038 you have unlock - fail but phone unlocked] br |
The Following User Says Thank You to dayman22 For This Useful Post: |
08-16-2012, 07:25 | #3 (permalink) |
Registered User Join Date: May 2004 Location: Romania Age: 43
Member: 64564 Status: Offline Thanks Meter: 13 | better pres read info...is more safe Selected model: E1200M Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F815 Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 3518******* Phone slave IMEI: 3518********* Phone SW: E1200XFLF2 Phone CSC: E1200OXFLF2 Phone BT ADDR: 0000-00-000000 Phone SN: RV1C746A6F Deactivated MSL - TRUE [FREZEE]: 05416640 [NET Lock]: 69154810 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 [Phone Lock]: 00000000 Read info - ok Elapsed time: 52 second, sw ver: 3.5.0038 |
The Following User Says Thank You to radu_adriansv For This Useful Post: |
08-25-2012, 14:17 | #4 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Estonia Age: 37
Member: 154612 Status: Offline Thanks Meter: 824 | Quote:
Thanks | |
08-31-2012, 17:32 | #5 (permalink) |
Junior Member Join Date: Sep 2007
Member: 594063 Status: Offline Thanks Meter: 5 | Selected model: E1200M Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F815 Sending loader2... OK Start NOR flash NOR flash - ok LPD flash - ok Start Flash TFS Send Dir - fail Send TFS - fail Elapsed time: 205 second, sw ver: 3.5.0038 Send Dir - fail ??? Send TFS - fail ???? help |
09-06-2012, 17:27 | #7 (permalink) |
Freak Poster Join Date: Jun 2004 Location: POLAND & BELGIUM Age: 42
Member: 67785 Status: Offline Thanks Meter: 20 | flash just first part problem with customization z3x support tfs orginal flash have tfi:/ orginal downloader no possible setting com 1.2.3 ... non activ |
09-17-2012, 16:08 | #9 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | Error reading unlock codes: Selected model: E1200M Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F815 Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 35229205118077 Phone slave IMEI: 35229205118077 Phone SW: E1200ZDLF2 Phone CSC: E1200OZDLF2 Phone BT ADDR: 0000-00-000000 Phone SN: RF1C70WRRD Deactivated MSL - TRUE [FREZEE]: 86705310 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 [Phone Lock]: 00000000 Read info - ok Elapsed time: 45 second, sw ver: 3.5.0038 i try like E1200M and E1200T, same result. in moment make FuBu and will try Direct unlock. can you fix code reading please. |
09-17-2012, 16:10 | #10 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | Selected model: E1200M Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F8C5 Sending loader2... OK Please wait for patching firmware... Already patched SW Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 35229205118077 Phone slave IMEI: 35229205118077 Phone SW: E1200ZDLF2 Phone CSC: E1200OZDLF2 Phone BT ADDR: 0000-00-000000 Phone SN: RF1C70WRRD Deactivated MSL - TRUE Unlock - FAIL Elapsed time: 53 second, sw ver: 3.5.0038 |
09-17-2012, 16:11 | #11 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | strange. like E1200T is unlocked with Direct unlock ------------------------------------------------------------------------------- Selected model: E1200T Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F815 Sending loader2... OK Please wait for patching firmware... Already patched SW Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 00000000000000 Phone slave IMEI: 00000000000000 Phone SW: E1200ZDLF2 Phone CSC: E1200OZDLF2 Phone BT ADDR: 0000-00-000000 Phone SN: RF1C70WRRD Deactivated MSL - TRUE Unlock - ok Elapsed time: 46 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
10-11-2012, 08:14 | #12 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 49
Member: 232607 Status: Offline Sonork: 100.1585040 Thanks Meter: 260 | Selected model: E1200T Selected com port: COM29 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F8C5 Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 35186105107295 Phone slave IMEI: 35186105107295 Phone SW: E1200XXLCA Phone CSC: E1200OXALCB Phone BT ADDR: 0000-00-000000 Phone SN: RV1C52RQDE Deactivated MSL - TRUE [FREZEE]: 57948000 [NET Lock]: 70545230 [Subset Lock]: 70545230 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 [Phone Lock]: 00000000 Read info - ok Elapsed time: 46 second, sw ver: 3.5.0038 yes working e1200 select as e1200t |
10-19-2012, 13:57 | #13 (permalink) |
Junior Member Join Date: Jul 2012 Location: malindi kenya
Member: 1788403 Status: Offline Thanks Meter: 0 | hello i always get this problem when unlocking small phnes like e1200------------------------------------------ Selected model: E1200M Selected com port: COM14 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F815 Sending loader2... OK Please wait for patching firmware... Timeout damp Read - fail Patch MSL - FAIL Elapsed time: 29 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
11-21-2012, 11:23 | #14 (permalink) |
Junior Member Join Date: Jul 2004
Member: 71191 Status: Offline Thanks Meter: 2 | Selected model: E1200 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F8C5 Sending loader2... OK Please wait for patching firmware... Already patched SW Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 00000000000000 Phone slave IMEI: 00000000000000 Phone SW: E1200ZDLF2 Phone CSC: E1200OZDLF2 Phone BT ADDR: 0000-00-000000 Phone SN: RF1C71L3KR Deactivated MSL - TRUE Unlock - ok Elapsed time: 56 second, sw ver: 3.5.0040 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
