05-11-2016, 21:08 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 280594 Status: Offline Thanks Meter: 21 | e210k security damaged Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Repair Selected model: SHV-E210K Software version: 25.3 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SHV-E210K Android version: 4.4.4 Product code: Phone version: E210KKTUKNK4 PDA version: E210KKTUKOB1 CSC version: E210KKTTKOB1 CSC country code: KOREA CSC sales code: KTT HW version: Phone S/N: Modem board: RF cal date: IMEI: 000000000000000 Checking Super user right... true Reading nv data... OK Security damaged Done with Samsung Tool PRO v.25.3 |
