11-24-2010, 20:42 | #34 (permalink) | |
Freak Poster Join Date: May 2008 Location: philippines Age: 45
Member: 771806 Status: Offline Thanks Meter: 51 | Quote:
no single unit comes back....? | |
11-25-2010, 02:19 | #36 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1009679 Status: Offline Thanks Meter: 166 | i have fully repaired one e2120 restart but a risky procedure mild reheat FLASH IC, then reflash. i think it's a design flaw of Samsung. they place main parts below keypad, will be stressed in the long run. |
11-25-2010, 02:24 | #37 (permalink) | |
Member: 1009679 Status: Offline Thanks Meter: 166 | Quote:
maybe by removing that PCB is heated and defective parts was repaired. but removing that is nothing to do. | |
11-25-2010, 03:52 | #38 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Quote:
Many Time ago I posted it that only solution is to change PCB (Board), but you people is trying with software. | |
11-25-2010, 03:58 | #39 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 305311 Status: Offline Thanks Meter: 227 | PCB MEANS A printed circuit board, or PCB, is used to mechanically support and electrically connect electronic components using conductive pathways, tracks or signal traces etched from copper sheets laminated onto a non-conductive substrate. It is also referred to as printed wiring board (PWB) or etched wiring board. A PCB populated with electronic components is a printed circuit assembly (PCA), also known as a printed circuit board assembly (PCBA). PCBs are inexpensive, and can be highly reliable. They require much more layout effort and higher initial cost than either wire-wrapped or point-to-point constructed circuits, but are much cheaper and faster for high-volume production. Much of the electronics industry's PCB design, assembly, and quality control needs are set by standards that are published by the IPC organization. |
The Following User Says Thank You to ronkiton For This Useful Post: |
11-25-2010, 04:30 | #40 (permalink) |
No Life Poster Join Date: May 2007 Location: Philippines
Member: 502531 Status: Offline Thanks Meter: 897 | final sulution for this problem > REHEAT LCD tested many times, no back job, no wasting forum space and time |
The Following 3 Users Say Thank You to .:UnitedGSM:. For This Useful Post: |
11-25-2010, 04:41 | #42 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Phillipines
Member: 614098 Status: Offline Thanks Meter: 192 | Put Phone to trash can.. 100% solution tested by others.. lol... kahit mag Change board wala din.. kasi nga sira ng e2120 yan.. TAPON ang the Best Solution |
11-25-2010, 04:46 | #44 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | i have fully repaired one e2120i restart by ufs.. somewhere in this forum i got this trick & succeed. |
The Following User Says Thank You to Rin2 For This Useful Post: |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Pic Solution | jan | Nokia Hardware & Hardware Repair | 8 | 10-11-2010 10:56 |
100% unlock1 for Nokia 6150 v5.17 ------,......... | cIVIc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 02:00 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
