Unlock Server
Old 11-24-2010, 18:11   #31 (permalink)
Member: 239004
Sonork: 100.1589817
pcb iz your compleet bord .... main bord off mobile ,,,
Old 11-24-2010, 18:16   #32 (permalink)
MasoudSAMSUNG's Avatar
Member: 1153045
Sonork: 100.1638693
of course you solution work fine mr.Blang
But i solved a lot of phone via SW jobs (ereasing/full flash)
Old 11-24-2010, 18:25   #33 (permalink)
Member: 161646
Originally Posted by sid-ahmed View Post
what is the pcb please
buy other phone in market
Old 11-24-2010, 19:42   #34 (permalink)
adamsquall's Avatar
Member: 771806
Originally Posted by Z3X-HelpeR View Post
my solution in my oppinion for arabian user
maybe we have this problem after try to flash it by arabic flash file or come to us with this problem
1st thing we will flash it by this frimware
E2120XEIH2.rar - 4shared.com - online file sharing and storage - download
it's not arabic flash file if it work good it's not hardware problem it's in arabic flash file
2 try to flash it by this frimware
E2120JPII3.rar - 4shared.com - online file sharing and storage - download
and make unlock
more than 25 pices 100% worked with me
B.R
Mohamed EL-GmmaL
u sure mates.....?
no single unit comes back....?
Old 11-25-2010, 01:12   #35 (permalink)
I-IM-P's Avatar
Member: 1190533
Sonork: 100.1594249
help me e2120 flash id 49 support flat.thanks
The Following User Says Thank You to I-IM-P For This Useful Post:
Old 11-25-2010, 01:19   #36 (permalink)
Member: 1009679
i have fully repaired one e2120 restart but a risky procedure mild reheat FLASH IC, then reflash.
i think it's a design flaw of Samsung. they place main parts below keypad, will be stressed in the long run.
Old 11-25-2010, 01:24   #37 (permalink)
Member: 1009679
Originally Posted by pradeep_kus View Post
i have this pic but i have not tested yet
pls user test and post result
http://img820.imageshack.us/img820/4725/xbbryw.jpg
Uploaded with ImageShack.us
this solution was tested by myself. 100% NOT WORKING!
maybe by removing that PCB is heated and defective parts was repaired. but removing that is nothing to do.
The Following 2 Users Say Thank You to Rabatu For This Useful Post:
Old 11-25-2010, 02:52   #38 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Originally Posted by blang View Post
E2120, E2120i, E2120B - 100% restart solution!!!
change pcb and phone will work 100%.
other solution not exist.
If someone have other solution you can post only in this tread!!!
Keep z3x section clear and easy for searching if someone need real solutiion and real help. not waste time.
if i will see 1more post in z3x section about this problem - tread poster will be blocked from z3x section forever.
Many Time ago I posted it that only solution is to change PCB (Board), but you people is trying with software.
Old 11-25-2010, 02:58   #39 (permalink)
Member: 305311
PCB MEANS
A printed circuit board, or PCB, is used to mechanically support and electrically connect electronic components using conductive pathways, tracks or signal traces etched from copper sheets laminated onto a non-conductive substrate. It is also referred to as printed wiring board (PWB) or etched wiring board. A PCB populated with electronic components is a printed circuit assembly (PCA), also known as a printed circuit board assembly (PCBA).
PCBs are inexpensive, and can be highly reliable. They require much more layout effort and higher initial cost than either wire-wrapped or point-to-point constructed circuits, but are much cheaper and faster for high-volume production. Much of the electronics industry's PCB design, assembly, and quality control needs are set by standards that are published by the IPC organization.
The Following User Says Thank You to ronkiton For This Useful Post:
Old 11-25-2010, 03:30   #40 (permalink)
Member: 502531
final sulution for this problem > REHEAT LCD
tested many times, no back job, no wasting forum space and time
The Following 3 Users Say Thank You to .:UnitedGSM:. For This Useful Post:
Old 11-25-2010, 03:38   #41 (permalink)
Member: 1318884
reheat pcb board or lcd is the best way to e2120 blinking logo
for more info kindly pm mr eric mce
hehehe lol
Old 11-25-2010, 03:41   #42 (permalink)
rafzkie_24's Avatar
Member: 614098
Put Phone to trash can..
100% solution
tested by others..
lol...
kahit mag Change board wala din..
kasi nga sira ng e2120 yan..
TAPON ang the Best Solution
Old 11-25-2010, 03:42   #43 (permalink)
Crazy Poster
Member: 1300904
bakit sa lcd faps eric bwhahahahahah ) )
Old 11-25-2010, 03:46   #44 (permalink)
Rin2's Avatar
Member: 982335
Sonork: 100.1603225
i have fully repaired one e2120i restart by ufs..
somewhere in this forum i got this trick & succeed.
The Following User Says Thank You to Rin2 For This Useful Post:
Old 11-25-2010, 03:50   #45 (permalink)
Member: 345808
ust this its work 1000%
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-16-2010 04:52
Pic Solution jan Nokia Hardware & Hardware-Repair Area 8 10-11-2010 10:56
100% unlock1 for Nokia 6150 v5.17 ------,......... cIVIc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-10-1999 01:00
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-08-1999 09:14
Page generated in 0.43954 seconds with 12 queries
