12-10-2011, 13:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: United kingdom Age: 64
Member: 26440 Status: Offline Thanks Meter: 6 | *** e2230 cannot repair otp imei *** Selected model: E2230 Selected com port: COM12 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Writing ... OK Repair OTP - ok Elapsed time: 38 second, sw ver: 3.5.0029 |
12-20-2011, 12:36 | #6 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Croatia / Rijeka
Member: 83831 Status: Offline Thanks Meter: 11 | 100 % correct solution for IMEI repair E2230: use version 3.5.0029 and connect only USB cable mark model E2530 and write IMEI and S/N in fields go to settings tab and uncheck New Algo box press OTP repair and IMEI will be repaired BR |
The Following User Says Thank You to andrija For This Useful Post: |
02-02-2012, 13:38 | #7 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Colombia
Member: 193303 Status: Offline Sonork: 100.1613585 Thanks Meter: 104 | Selected model: E2330 Selected com port: COM22 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Not found code hash - fail safe read info - fail Elapsed time: 123 second, sw ver: 3.5.0032 ------------------------------------------------------------------------------- ???????? |
02-02-2012, 16:56 | #9 (permalink) |
Member: 83831 Status: Offline Thanks Meter: 11 | 100 % correct solution for unlock E2230: use version 3.5.0022 and use only USB cable mark model E2330 and press Read Codes when prompted insert USB cable Sometimes it must be repeated several times until phone is properly recognized by Z3X software |
02-13-2012, 16:07 | #11 (permalink) |
Member: 83831 Status: Offline Thanks Meter: 11 | Yes it works if You follow this instructions 100 % correct solution for IMEI repair E2230: use version 3.5.0029 and connect only USB cable mark model E2530 and write IMEI and S/N in fields go to settings tab and uncheck New Algo box fill IMEI and S/N in appropriate box press OTP repair and IMEI will be repaired BR |
The Following 2 Users Say Thank You to andrija For This Useful Post: |
02-23-2012, 16:10 | #12 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 448031 Status: Offline Thanks Meter: 4 | E2230 imei 100 % correct solution for IMEI repair E2230: use version 3.5.0029 and connect only USB cable mark model E2230 and write IMEI and S/N in fields fill IMEI and S/N in appropriate box press OTP repair and IMEI will be repaired Selected model: E2230 Selected com port: COM7 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Writing ... OK Repair OTP - ok Elapsed time: 12 second, sw ver: 3.5.0029 |
The Following User Says Thank You to pedjoni For This Useful Post: |
05-25-2012, 12:44 | #14 (permalink) |
Insane Poster Join Date: Dec 2011
Member: 1702235 Status: Offline Thanks Meter: 5 | Selected model: E2230 Selected com port: COM40 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Writing ... OK Repair OTP - ok Elapsed time: 14 second, sw ver: 3.5.0035 WORKED TO PUT IMEI BACK... just untick new algo in settings tab put marks on imei and sn write imei without last number coz it will not fit in other case.. worked like a bee hope it helps for someone... Still need to unlock this phone in the other hand... |
05-25-2012, 16:39 | #15 (permalink) |
Member: 1702235 Status: Offline Thanks Meter: 5 | Ok managed to unlock aswell here is the log -> Selected model: E2530 Selected com port: COM40 Selected speed port: 921600 Phone must be OFF Press * and connect phone by cable Connecting to Device... OK Wait for decrypted code... OK Decrypted time: 60 sec [PCK]:#0141*00000000# [NCK]:#0111*38397387# [SCK]:#0121*00000000# [SPCK]:#0133*98237812# [MCK]:#0199*78440317# Read info - ok Elapsed time: 77 second, sw ver: 3.5.0022 It's sad that we have to use different models and everything is mixed up, but best thing we still are able to do all unlock's Thanks for z3x, keep it up. |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
