02-27-2012, 19:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | E2230 imei 0 whats the solution? Selected com port: COM1 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... Aborted by user Elapsed time: 7 second, sw ver: 3.5.0034 ------------------------------------------------------------------------------- Selected model: E2230 Selected com port: COM157 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... Aborted by user Elapsed time: 4 second, sw ver: 3.5.0034 ------------------------------------------------------------------------------- Selected model: E2230 Selected com port: COM157 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Deactivate MSL - fail Read info - fail Elapsed time: 23 second, sw ver: 3.5.0034 ------------------------------------------------------------------------------- Selected model: E2232 Selected com port: COM157 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Deactivate MSL - fail Read info - fail Elapsed time: 48 second, sw ver: 3.5.0034 ------------------------------------------------------------------------------- Selected model: E2232 Selected com port: COM157 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Aborted by user Elapsed time: 42 second, sw ver: 3.5.0034 ------------------------------------------------------------------------------- Selected model: E2232 Selected com port: COM157 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Deactivate MSL - fail Repair - fail Elapsed time: 65 second, sw ver: 3.5.0034 ------------------------------------------------------------------------------- |
03-01-2012, 17:42 | #2 (permalink) |
Crazy Poster Join Date: May 2010
Member: 1302218 Status: Offline Thanks Meter: 8 | Selected model: E2232 Selected com port: COM5 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Deactivate MSL - fail Repair - fail Elapsed time: 39 second, sw ver: 3.5.0032 ------------------------------------------------------------------------------- |
03-02-2012, 11:30 | #3 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 448031 Status: Offline Thanks Meter: 4 | E2230 imei 100 % correct solution for IMEI repair E2230: use version 3.5.0029 and connect only USB cable mark model E2230 and write IMEI and S/N in fields fill IMEI and S/N in appropriate box press OTP repair and IMEI will be repaired Selected model: E2230 Selected com port: COM7 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Writing ... OK Repair OTP - ok Elapsed time: 12 second, sw ver: 3.5.002 |
03-05-2012, 10:14 | #6 (permalink) | |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Quote:
04-11-2012, 01:13 | #7 (permalink) | |
No Life Poster Join Date: Sep 2005 Age: 41
Member: 185279 Status: Offline Thanks Meter: 43 | Quote:
Don't work, I have E2230 with IMEI 00000000000000 after unlock with Z3X | |
04-27-2012, 08:58 | #9 (permalink) |
No Life Poster Join Date: Sep 2004 Location: in AXE control room Age: 54
Member: 84300 Status: Offline Thanks Meter: 74 | ------------------------------------------------------------------------------- Selected model: E2230 Selected com port: COM22 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK it stuck here Elapsed time: 338 second, sw ver: 3.5.0029 ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Selected model: E2530 Selected com port: COM22 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK B1A65867CC115A8EE517D11F5CAF766E8BCFA0C9 CA277FDD01E220002007FE7797E398ECA5D2B7F3 B1A65867CC115A8EE517D11F5CAF766E8BCFA0C9 B1A65867CC115A8EE517D11F5CAF766E8BCFA0C9 673AE98054948224E49C7B92E21EDA3708E99DD6 Calculated code please wait... Decrypted time: 43 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*47541916# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*68674803# this is Master(freeze) code safe read info - ok Elapsed time: 130 second, sw ver: 3.5.0029 -------------------------------------------------------------- TRY to with version 3.5.0029, select E2350, first if is IMEI damaged 000000, do repair OTP with right IMEI & S/N, then just press SAFE INFO in writing Flash selection |
The Following User Says Thank You to Crumarix1 For This Useful Post: |
05-21-2012, 16:15 | #10 (permalink) | |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | good solution Quote:
07-16-2012, 15:13 | #12 (permalink) | |
Junior Member Join Date: Nov 2010 Location: cape town south africa
Member: 1443428 Status: Offline Thanks Meter: 1 | thank its worlking 100% Quote:
thanks bro it works perfect | |
07-24-2012, 16:15 | #14 (permalink) |
Freak Poster Join Date: May 2001 Location: Cape Verde Age: 49
Member: 4596 Status: Offline Sonork: ssemmedo Thanks Meter: 3 | usinf the latest versio to unlock i get allways this message: Selected model: E2230 Selected com port: COM14 Selected speed port: 115200 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Deactivate MSL - fail Read info - fail Elapsed time: 82 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Selected model: E2350 Selected com port: COM14 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK Search diag port... Timeout Read info - fail Elapsed time: 108 second, sw ver: 3.5.0038 what can be wrong . please help me. |
07-24-2012, 16:57 | #15 (permalink) |
Member: 4596 Status: Offline Sonork: ssemmedo Thanks Meter: 3 | no i get this message after installing the driver: Selected model: E2350 Selected com port: COM14 Selected speed port: 115200 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK Search diag port... OK (COM31) Deactivate MSL - fail Read info - fail Elapsed time: 42 second, sw ver: 3.5.0038 |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
