03-17-2015, 09:40 | #18 (permalink) |
Freak Poster Join Date: May 2004 Location: inside
Member: 67450 Status: Offline Thanks Meter: 57 | Z3X EasyJtag Software ver. 1.8.1.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 05050xxxxxxxxxxxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:3186 mV CMD Active Level:3279 mV SD Card Information SD CID : 035344535430324780504D2796008880 SD CSD : 002600325F5A83D3BEFBCFFF9280401A SD Manufacturer ID: 0003 , OEM ID: 5344 SD Date: 08/2008 Rev.0x80 SD NAME: ST02G , S/N: 1347233686 SD NAME (HEX): 53543032470000 SD Capacity: 1959 MB SD Permanent Write Protection: No SD Temporary Write Protection: No Done. Z3X EasyJtag Software ver. 1.8.1.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 05050xxxxxxxxxxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:3196 mV CMD Active Level:3269 mV SD Card Information SD CID : 03534453543031478020F226A9008740 SD CSD : 002600325F5983D3BEFBCFFF92404018 SD Manufacturer ID: 0003 , OEM ID: 5344 SD Date: 07/2008 Rev.0x80 SD NAME: ST01G , S/N: 552740521 SD NAME (HEX): 53543031470000 SD Capacity: 979 MB SD Permanent Write Protection: No SD Temporary Write Protection: No Done. Skip loading eMMC Addon Firmware CMD Pullup Level:2155 mV CMD Active Level:2217 mV Output file :\Rabota\mio\garmin\255w\255w\test.bin Reading 0x000000020000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Read Check Failed, Reason: CARD Data FIFO Timeout Error Z3X EasyJtag Software ver. 1.8.1.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 05050xxxxxxxxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:2145 mV CMD Active Level:2227 mV SD Card Information SD CID : 03534453543031478020F226A9008740 SD CSD : 002600325F5983D3BEFBCFFF92404018 SD Manufacturer ID: 0003 , OEM ID: 5344 SD Date: 07/2008 Rev.0x80 SD NAME: ST01G , S/N: 552740521 SD NAME (HEX): 53543031470000 SD Capacity: 979 MB SD Permanent Write Protection: No SD Temporary Write Protection: No Done. Z3X EasyJtag Software ver. 1.8.1.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2145 mV CMD Active Level:2227 mV Output file :\Rabota\mio\garmin\255w\255w\test.bin Reading 0x000000020000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Done. Read Speed: 524 kB/s Z3X EasyJtag Software ver. 1.8.1.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2145 mV CMD Active Level:2227 mV Output file :\Rabota\mio\garmin\255w\255w\test.bin Reading 0x000002000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Done. Read Speed: 628 kB/s Z3X EasyJtag Software ver. 1.8.1.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 05050xxxxxxxxxxxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:3186 mV CMD Active Level:3279 mV SD Card Information SD CID : 035344535430324780504D2796008880 SD CSD : 002600325F5A83D3BEFBCFFF9280401A SD Manufacturer ID: 0003 , OEM ID: 5344 SD Date: 08/2008 Rev.0x80 SD NAME: ST02G , S/N: 1347233686 SD NAME (HEX): 53543032470000 SD Capacity: 1959 MB SD Permanent Write Protection: No SD Temporary Write Protection: No Done. Z3X EasyJtag Software ver. 1.8.1.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 05050xxxxxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:3196 mV CMD Active Level:3269 mV SD Card Information SD CID : 03534453543031478020F226A9008740 SD CSD : 002600325F5983D3BEFBCFFF92404018 SD Manufacturer ID: 0003 , OEM ID: 5344 SD Date: 07/2008 Rev.0x80 SD NAME: ST01G , S/N: 552740521 SD NAME (HEX): 53543031470000 SD Capacity: 979 MB SD Permanent Write Protection: No SD Temporary Write Protection: No Done. Z3X EasyJtag Software ver. 1.8.1.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 05050xxxxxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:3196 mV CMD Active Level:3279 mV SD Card Information SD CID : 0353445345303447800362432F00A390 SD CSD : 400E0032535900001D8A7F800A404054 SD Manufacturer ID: 0003 , OEM ID: 5344 SD Date: 03/2010 Rev.0x80 SD NAME: SE04G , S/N: 56771375 SD NAME (HEX): 53453034470000 SD Capacity: 3781 MB SD Permanent Write Protection: No SD Temporary Write Protection: No Done. Z3X EasyJtag Software ver. 1.8.1.0 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 05050xxxxxxxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:2093 mV CMD Active Level:2206 mV SD Card Information SD CID : 035344535430314780302A0BD30082E6 SD CSD : 002600325F5983D3ADDBCFFF924040A6 SD Manufacturer ID: 0003 , OEM ID: 5344 SD Date: 02/2008 Rev.0x80 SD NAME: ST01G , S/N: 808061907 SD NAME (HEX): 53543031470000 SD Capacity: 979 MB SD Permanent Write Protection: No SD Temporary Write Protection: No Done. |
03-18-2015, 04:41 | #19 (permalink) | |
Freak Poster Join Date: Dec 2004 Age: 38
Member: 102076 Status: Offline Thanks Meter: 41 | Quote:
and make TAB for option to make a RCP file,, | |
The Following User Says Thank You to chickboy For This Useful Post: |
03-18-2015, 08:43 | #20 (permalink) |
Freak Poster Join Date: Jan 2010 Age: 14
Member: 1214273 Status: Offline Thanks Meter: 136 | Mr. Blang, it's good idea about Garmin supporting. Maybe you could think about other devices, ex. smart TV's ? There is many things that we can fix with good software - Easy JTAG. |
