11-13-2017, 19:38 | #1 (permalink) |
Insane Poster Join Date: Feb 2014 Location: uk
Member: 2136836 Status: Offline Thanks Meter: 15 | edge G935F on 7.0 g935fxxu1dqb1 wont root i have try to root this phone with z3x box but locks the phone in start up logo samsungs hangs, i have try drk did not do out so i had to re flash it with above to get it working. i have try twrp-3.1.0-0-hero2lte.img and also SR3-SuperSU-v2.82-SR3-20170813133244 and did not work it frozen on logo when i used odin. any ideas gratefully welcome. thank you |
11-13-2017, 19:43 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | Quote:
twrp-3.1.1-0-hero2lte.img.tar from https://dl.twrp.me/hero2lte/ Flash with Odin un-tick auto reboot After flashing TWRP, boot into TWRP.. From wipe select Format Data... type yes and after wipe go back to Main Menu and select reboot, reboot to recovery.. After reboot browse to install and flash Supersu 2.82 (you can use SD-Card or OTG cable): Reboot your device... it will take up to 5 minutes Wipe data is a MUST because when you swipe TWRP it will trigger dm-verity, and if you don't wipe you will be unable to boot Last edited by voltran2008; 11-13-2017 at 19:52. | |
The Following User Says Thank You to voltran2008 For This Useful Post: |
11-13-2017, 21:52 | #3 (permalink) | |
Member: 2136836 Status: Offline Thanks Meter: 15 | Thank you so much Quote:
