10-01-2013, 18:55 | #1 (permalink) |
Crazy Poster Join Date: May 2012
Member: 1763087 Status: Offline Sonork: 100.1647199 Thanks Meter: 4 | Efs or nvm item, yellow screen |
10-03-2013, 13:18 | #3 (permalink) |
Member: 1763087 Status: Offline Sonork: 100.1647199 Thanks Meter: 4 | model GT-S7560M , after the software, a screen appears yellow in the middle of the cell with some configuration, like something from the genre test mode, even recording the IMEI, this screen does not come out and the boot menu does not appear, you are holding the power button the device off without the right menu and the configuration of gmail, when connected after reset also does not appear |
10-03-2013, 15:24 | #4 (permalink) | |
No Life Poster Join Date: May 2009 Location: android efs
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | Quote:
write efs same set your problem solve wbr [email protected] | |
The Following User Says Thank You to rajakhank3 For This Useful Post: |
10-12-2013, 04:46 | #8 (permalink) |
Member: 1763087 Status: Offline Sonork: 100.1647199 Thanks Meter: 4 | Here is the exact solution for this problem which i have recently had! You have to root your phone and install Terminal Emulator from Google Play. Open terminal emulator and type as ; su rm /efs/FactoryApp/keystr rm /efs/FactoryApp/factorymode echo -n ON >> /efs/FactoryApp/keystr echo -n ON >> /efs/FactoryApp/factorymode chown 1000.1000 /efs/FactoryApp/keystr chown 1000.1000 /efs/FactoryApp/factorymode chmod 0744 /efs/FactoryApp/keystr chmod 0744 /efs/FactoryApp/factorymode reboot Worked for me. Also brought back my lock screen and my power button options, i do think a rom messed about with my efs file. Thank you again "inflock" |
