07-23-2016, 15:40 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Iran
Member: 2014899 Status: Offline Thanks Meter: 14 | Emergency call g920f With the large version with any version above 6.0.1 It would not Hong had Soviet Logo When writing files cert , nv the following errors BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G920F Software version: 26.0 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: Phone version: PDA version: G920FXXS3DPC2 CSC version: G920FVFG3DPC1 CSC country code: Slovenia CSC sales code: SIM HW version: Phone S/N: RF8G400640P Modem board: RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.26.0 REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G920F Software version: 26.0 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: Phone version: G920FXXS3DPC2 PDA version: G920FXXS3DPC2 CSC version: G920FVFG3DPC1 CSC country code: Slovenia CSC sales code: SIM HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 88 1A 87 0D D6 05 00 00 00 00 00 00 00 00 00 00 Reading nv data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.26.0 |
