02-15-2018, 08:16 | #1 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2796441 Status: Offline Thanks Meter: 9 | ENG-ROOT (Boot) dependency of Android main version After Android 8.0 release and keep BL rev.1 , Can I use / compatible this Android 7.0 ENG-ROOT on G955F Android 8.0 binary? How about dependency between ENG-ROOT file and Android Main version? ** Additional question: I googled and downloaded G955F-ENG-ROOT file which not tripped KNOX flag in their description. I tried this ENG-root file flash to my personal G955F phone which phone using Google account(surely FRP locked), But my phone said in Odin mode : Custom binary blocked by FRP LOCK One doubt , if this ENG-root file is really official samsung ENG-ROOT file, i think this official ENG-root can flash even though FRP LOCK is enabled. What do you think? Last edited by SMN9999; 02-15-2018 at 08:46. |
02-17-2018, 09:05 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | Any signed data could be flashed through Odin FULL FLASH , COMBINATION FILE But custom binary its UNSIGNED code FRP BLOCK any UNSIGNED code flashing , caused by OEM LOCK ( bootloader lock ) When OEM its unprotected , then you can flash unsigned data , but this feature is intended for developers to run unsigned code such as , twrp , cwm , etc ( custom recovery’s ) , for flashing custom roms , modify fs , rom cooking .... Then , if you have OEM unlock , you can get access to hole bussines , but if you have OEM lock , then you can only play with signed data , backdoors, forensic hw |
The Following User Says Thank You to rogerboogie For This Useful Post: |
02-17-2018, 09:12 | #3 (permalink) | |
Member: 2796441 Status: Offline Thanks Meter: 9 | Quote:
I known that currently we have only G930 / G935 qualcomm model has REAL eng-root(kernel). Hope to more G950/G955/N950 Qualcomm/Exynos eng-root files also release soon. Sent from my SM-G955F using Tapatalk | |
The Following User Says Thank You to SMN9999 For This Useful Post: |
