01-31-2016, 08:23 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: king of saudia arabia
Member: 2501469 Status: Offline Sonork: speakme2009 Thanks Meter: 33 | Erasing EE lock... error SM-J700H help needed all brothers i have big prob 2 dayes cant slove it and no one help UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J700H Software version: 24.2 Searching Samsung USB Flash Interface... detected COM12 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.24.2 |
02-19-2016, 00:04 | #10 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Downgrade your sboot and modem and erase frp But be carefull for the rollback protection RP if you downgrade the RP your phone was dead Br Shahzaib Jahangir |
02-19-2016, 09:59 | #12 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: DUBAI , PAKISTAN
Member: 888420 Status: Offline Sonork: 100.1611861 Thanks Meter: 394 | Quote:
